Need help! GSR motor won't start
Old Oct 29, 2007 | 06:49 PM
danny_ha's Avatar
Default Need help! GSR motor won't start
I've got a 98 civic hatch with a gsr swap and it won't start. The battery, timing belt tensioner, spark plugs, and spark plug wires are brand new, so I know it's non of these. I've also checked all the grounds and it doesn't seem like it's that either. Don't think it's the starter either. If anyone might know what this could be, please help.
Old Oct 29, 2007 | 07:00 PM
JKov240's Avatar
Default Re: Need help! GSR motor won't start (danny_ha)
You need fuel, spark, compression, and timing for a motor to run.
Are you sure you have those?
Old Oct 29, 2007 | 07:13 PM
gsrhatch2356's Avatar
You really should post more info like does it the starter turn and it dosent start? have you tested for spark and fuel? and what were the results? things like this can help other people better guide you in the right direction. and another biggie has this motor ran recently or did you just swap it in?
Old Oct 29, 2007 | 07:58 PM
danny_ha's Avatar
Default Re: Need help! GSR motor won't start (JKov240)
I have all of those.
Old Oct 29, 2007 | 08:02 PM
danny_ha's Avatar
Default Re: Need help! GSR motor won't start (gsrhatch2356)
The starter is turning, but nothing happens. And no, the motor was not just swapped. I was driving the car this morning to work, got home and I tried to leave, and the car wouldn't start. And there was no need for the rudeness by the way.
Old Nov 6, 2007 | 07:33 PM
danny_ha's Avatar
anyone?
Old Nov 6, 2007 | 07:37 PM
Fo-Do Fanatic's Avatar
is the starter clicking when you turn the key to "ON"???
Old Nov 6, 2007 | 07:40 PM
StingRay4's Avatar
does the motor turn over?
Old Nov 6, 2007 | 08:06 PM
92civicx's Avatar
Default Re: (StingRay4)
so it cranks but doesn't start. This happened to me the first thing i did was...
1. check fuses
2. this was the last thing i did but the only thinng that work. i advanced the dizzy, unbolt the top bolt on the dizzy and put it towards the firwall. and it started. if that doesn't work
3. take out cylinder one spark plug connect to the wire, then put in on the valve cover. if you see a spark then you have it.
3.when you turn the key not on the starting pisition you should hear the fuel pump pumping in the back of the car. if you don't you need a fuel pump.
try these things and let us know
Old Nov 6, 2007 | 10:06 PM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny_ha &raquo;</TD></TR><TR><TD CLASS="quote">And there was no need for the rudeness by the way.</TD></TR></TABLE>
I didn't sense any rudeness, but someone giving advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 &raquo;</TD></TR><TR><TD CLASS="quote">You need fuel, spark, compression, and timing for a motor to run. Are you sure you have those?</TD></TR></TABLE>
True, listen to 92civicx as far as the fuel and spark goes, do a compression check and also make sure the dizzy rotor/cap are good. If the car is turning over, then the starter is good.
Shane
Old Nov 7, 2007 | 10:19 PM
Default Re: Need help! GSR motor won't start (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicx &raquo;</TD></TR><TR><TD CLASS="quote">3.when you turn the key not on the starting pisition you should hear the fuel pump pumping in the back of the car. if you don't you need a fuel pump.
i wouldn't go as far as saying that. my buddy has a 93 Civic hatch dx and you can't hear his fuel pump what-so-ever in or outside the car. my geo doesn't do it either
Old Nov 8, 2007 | 10:29 AM
danny_ha's Avatar
Default Re: Need help! GSR motor won't start (Fo-Do Fanatic)
the starter is clicking, but the motor isn't turning over. i even replaced the starter just to be sure, but still nothing. i've already checked and replaced all the fuses as well.
Old Nov 8, 2007 | 10:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny_ha &raquo;</TD></TR><TR><TD CLASS="quote">the starter is clicking, but the motor isn't turning over. i even replaced the starter just to be sure, but still nothing. i've already checked and replaced all the fuses as well.</TD></TR></TABLE>
Did you check the grounds? Last time my car wouldn't start, that was the problem.
-Shane
Old Nov 8, 2007 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
thats exactly what i was going to say. Check all your grounds and see if your car will start. sometimes on my geo i have to have the key on the on position for like 5-10 seconds for it to get the motor to turn over. the starter clicks and all, yes i know i need to get a new starter.
once againk, check the grounds.
Old Nov 8, 2007 | 11:21 AM
danny_ha's Avatar
yea, already did that too. checked the main ground, battery ground, all of them are good.
Old Nov 8, 2007 | 11:22 AM
danny_ha's Avatar
does anyone know the order the spark plug wires are suppose to go in? i was messing with them this morniing to see if that was the problem and i can't remember the order they go in.
Old Nov 8, 2007 | 11:35 AM
They should ba marked. If not it's pretty common sensical as far as the length of each should give it away. Unless you mean you took them out of the distrubutor. If that's the case, then I'll have to check and get back with you.
-Shane
Old Nov 8, 2007 | 11:37 AM
blanco617's Avatar
heres the firing order
Old Nov 8, 2007 | 11:44 AM
b20egX's Avatar
I had the exact same thing happen, and with mine it was the wiring for the fuel pump. Check that
Old Nov 8, 2007 | 02:14 PM
danny_ha's Avatar
Default Re: (b20egX)
thanks. i'll try that.
Old Nov 8, 2007 | 04:00 PM
dkid15's Avatar
find the problem?
Old Nov 14, 2007 | 08:21 AM
danny_ha's Avatar
Default Re: (dkid15)
yeah, i found the problem. apparently, when i got my alarm done at circuit city, they used my ignition wire to the starter as a ground for the alarm. pretty much, the alarm was stealing all the spark for the starter. that's why it wouldn't start. so, after countless days and $400 spent, the lesson that i learned: DON'T GO CIRCUIT CITY FOR ALARMS!!! THEY WILL F**K YOUR CAR UP!!!
thanks to all the people on here for helping me out. the car runs like a champ
93WhiteHatch
Aug 28, 2011 11:48 AM
dkillahster
Sep 10, 2010 12:26 PM
pest247
Jul 21, 2007 09:25 AM
2kTeg
Feb 12, 2006 06:14 PM
