Really need help with my sputtering problem :(
Old Oct 29, 2007 | 06:48 PM
eg6madness's Avatar
Default Really need help with my sputtering problem :(
After i drive my civic and shutoff and come back before the car gets completely cold and try to start it up the car sputters like hell and wants to cut out. today i noticed that when it starts up and sputters a puff of white smoke comes out the exhaust.
the car will continue to sputter unless i rev it out. All the while it is sputtering it is smoking white but when it clears up it goes away.
if i drive the car while it sputters it will flat spot and then it will just pick up and shoot off (all at constant throttle). 3 weeks bad i blew my head gasket, the car mainly started sputtering on start up after that. I was thinking maybe the head gasket was gone again so i did a compression test and the car had consistant numbers on all 4 cylinders.
Need suggestions as soon as possible. It is starting to **** me off and i think it is hurting the motor.
P.S
before i put the JDM B18c in my car and i had the D15b vtec it would flat spot but it would never sputter on start up.
The B18C motor has P30 pistons, a slightly milled head. new rings, bearings and all.
Old Oct 30, 2007 | 11:05 AM
eg6madness's Avatar
Default Re: Really need help with my sputtering problem :( (eg6madness)
need help
eg6madness
Nov 4, 2007 10:30 PM
JDM-EJ698
Jul 23, 2006 01:36 PM
premier_ek9
Jul 9, 2006 05:55 PM
kaj
Jan 24, 2004 03:12 PM
egcivic
Nov 6, 2003 08:03 AM
