antenna block off plate
Old Oct 29, 2007 | 11:21 AM
EJ8freek's Avatar
Default antenna block off plate
When you install the block-off plate, how do you take apart the antenna? Doesn't that mean you'll get no reception for radio?
Old Oct 29, 2007 | 11:27 AM
electron_si's Avatar
Default Re: antenna block off plate (ej8freek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8freek &raquo;</TD></TR><TR><TD CLASS="quote"> When you install the block-off plate, how do you take apart the antenna? Doesn't that mean you'll get no reception for radio? </TD></TR></TABLE>
the point of the plate is if you are running a radio block off plate (i am) or you have satelite radio and dont use am/fm
Dont get the blockoff plate if you want to keep your antena
Old Oct 29, 2007 | 11:56 AM
crazyguy's Avatar
i have the antenna block off plate and i took off the whole antenna assembly .
Old Oct 29, 2007 | 12:02 PM
hatch_'s Avatar
i have the atenna block off plate. my antenna is relocated towards the spoiler on the roof, kinda like on the vw jetta's. i bought it like that though.
Old Oct 29, 2007 | 12:09 PM
Bazza's Avatar
the block off plate basically is a relocator. it closes off where your antenna is and then you really dont have one unless you install one somewhere else
theres a special tool to take off the thing its like a horseshoe shape with 2 little flat ends... it fits on and you can take it apart rather easy check your other post about antenna.. i wrote something in there for ya. also a new antenna kit comes with the tool to remove the old.
Old Nov 4, 2007 | 04:29 PM
robble36's Avatar
Default Re: (Bazza)
can someone give me the part # for the antenna plate block off and the gasket for 97-00 civics ... dealership is confused and can find only EG ones
Old Jan 21, 2008 | 05:02 PM
addsmack's Avatar
Default Re: (robble36)
Bringing this one back....
I ordered the plate and rubber gasket and screws from majestic. Is there another back piece to the block off? I seem to be missing the location that the plate screws into. Help? Anyone?
Old Jan 21, 2008 | 05:06 PM
95sloweg's Avatar
Deleted post. did not realize the dates on the other posts .
Modified by 95sloweg at 9:20 PM 1/21/2008
Old Jan 21, 2008 | 05:26 PM
addsmack's Avatar
Default Re: (95sloweg)
Yep it's older, but I didnt want to get flamed for not searching. I searched, found nothing, now I need assistance.
Thanks,
Old Jan 22, 2008 | 02:06 PM
addsmack's Avatar
Anyone?
Old Jan 22, 2008 | 03:09 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: antenna block off plate (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">i have the antenna block off plate and i took off the whole antenna assembly .</TD></TR></TABLE>
as did i..
Old Jan 22, 2008 | 03:12 PM
crazyguy's Avatar
i took off the entire antenna.thats he purpose of the block off plate
Old Jan 22, 2008 | 03:36 PM
user 98292739's Avatar
No block of plate is to make it cleaner.
i have the block off plate and then i purchased a metra antenna and have the antenna in my dash.
boom clean smooth car with radio still.
thx god i have the fing radio my hasport mounts makes cd playing impossible.
Old Jan 22, 2008 | 06:14 PM
addsmack's Avatar
Old Jan 22, 2008 | 08:09 PM
h22ek9forme's Avatar
Default Re: (addsmack)
where are you guys buying this plate?
or what is the part # from honda
Old Jan 22, 2008 | 10:03 PM
da1lydr1ver's Avatar
to my recolection, the blockoff plate is the plate itself, a rubber gasket, and 2 screws. i picked mine up at a junkyard. that should be all you need.
Old Jan 22, 2008 | 10:07 PM
saywhat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by addsmack &raquo;</TD></TR><TR><TD CLASS="quote">
It screws straight into the roof, there is no back plate.
Old Jan 22, 2008 | 10:20 PM
Default Re: (saywhat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saywhat &raquo;</TD></TR><TR><TD CLASS="quote">
It screws straight into the roof, there is no back plate.</TD></TR></TABLE>
also a good place to find these is on ebay. they go for pretty cheap and they are still OEM honda.
I just pushed my antenna down into the a pillar, i didn't feel like pulling it out. I did notice that one of the screws is a little long and doesn't put very much pressure on the gasket, im going to reverse the screws to see if that makes a dif.
Old Jan 22, 2008 | 10:58 PM
pkdog167's Avatar
Default Re: (electron_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si &raquo;</TD></TR><TR><TD CLASS="quote">
I just pushed my antenna down into the a pillar</TD></TR></TABLE> That's what I did too.
Old Jan 23, 2008 | 03:48 AM
addsmack's Avatar
I guess I need to clarify.... I have a del Sol. It's not a roof antenna.
Old Jan 23, 2008 | 03:55 AM
pdiggitydogg's Avatar
Did you order #10, or a generic civic antenna block off plate?
Im guessing the latter, huh?
The civic block off plate is pretty different, and designed for A pillar mounted antennas (as you probably figured out). I wasnt even aware that S models were offered w/o a radio...
(plate # 39152-SR2-A00)
(screw # 93903-444G0)
Old Jan 23, 2008 | 04:41 AM
i also bought mine off ebay seems to be the cheapest. and yes it was just gasket. plate. screws/
Old Jan 23, 2008 | 05:31 AM
instrument's Avatar
take it to a autobody shop, get it filled and painted over, block off plates are gay.
Old Jan 23, 2008 | 06:48 AM
vestalfootball72
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">take it to a autobody shop, get it filled and painted over, block off plates are gay.</TD></TR></TABLE>
good answer
Old Jan 23, 2008 | 07:48 AM
addsmack's Avatar
Default Re: (pdiggitydogg)
I ordered number 9 and 10 in that pic. It's the screws, a plastic plate, and a rubber grommet. No place for it to screw to.
ghey.
