Suspension & Brakes Theory, alignment, spring rates....
Do Eibach springs make noise?
Old Oct 29, 2007 | 10:21 AM
tlcivic's Avatar
Default Do Eibach springs make noise?
i had a question wondering if eibach sportline springs make noises, because tein stechs come with that rubber thing to prevent noise, and eibachs dont. thanks.
Old Oct 29, 2007 | 12:15 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My H&R springs never made any noise that I can remember, and they didn't have any rubber on the coils. But if you get the Eibachs and they do make noise, you can buy the rubber coil isolator things from many different places.
Old Oct 29, 2007 | 12:32 PM
TunerN00b's Avatar
Default Re: Do Eibach springs make noise? (tlcivic)
My GC extended upper mounts (top hats) came with what seems to be a polyurethane ring, to go between the spring and mount, which makes noise as the spring twists during compression. This should be about the only sound from springs, unless you are somehow going into coil bind.
elly7b
Feb 6, 2014 04:54 PM
guero2craze
Suspension & Brakes
12
Apr 29, 2007 02:30 AM
mugenman20
Sep 17, 2004 01:54 PM
