need a lil auto to manual help...
Old Oct 29, 2007 | 07:07 AM
miguel329's Avatar
Default need a lil auto to manual help...
well i have started converting my auto 95 hatch to manual... i plan on using my 92 integra change over only becuase its fully built,have the turbo and everything for it still and only thing my trans is cable and id like to keep it becuase i got it rebuilt last summer,Got lsd added and its fresh...so i was on my way to get the hydro lines at the junk yard and a buddy of mine said not to just to get a 90 - 93 integra pedal and cable assembly.. will this work is there anything else to it thanks alot guys
Old Oct 29, 2007 | 07:52 AM
gsxr1k05's Avatar
Default Re: need a lil auto to manual help... (miguel329)
pm'd
edit.. posted for all to see
if your trans is cable, and you want to keep it, why do you need to hydro lines? the pedal assembly from any 92-00 civic and 94-00 teg will work. if the 90-93 teg pedals are 2 piece like the aforementioned, then they will work as well. the only difference is the type of connection that the throttle cable connects to the gas pedal with. i can tell you though, that removing the ENTIRE steering collum will make this process much easier. just get a sharpie and scribe a line from the shaft to the joint where the colum bolts to it and you wont have any issues lining it back up
Old Oct 29, 2007 | 09:34 AM
Bakeoff's Avatar
Default Re: need a lil auto to manual help... (gsxr1k05)
Doesn't the cable stop on the firewall? If it rests there and not on the pedal assembly, it won't work. Been too long since I've been in a DA or EF to think about it.
Otherwise, using the hydro setup and get a hydro to cable conversion isn't tough.
Old Oct 29, 2007 | 09:58 AM
Luserkid's Avatar
Default Re: need a lil auto to manual help... (Bakeoff)
Gas and Brake pedal can be from 88-00 Civic and 90-01 Integra. If you want to go cable trans then you need a 88-91 Civic or 90-93 Integra clutch setup along with clutch cable.
That wont be your biggest problem as you will need a special upper trans mount to make this work. Im not sure if hasport has one out on the market but i know they could make you a custom one. If not what you need to do is take off the chassis upper trans mount point and swap it in with a manual THEN get the hydro to cable mount.
Old Oct 29, 2007 | 12:16 PM
miguel329's Avatar
Default Re: need a lil auto to manual help... (Luserkid)
are you talking about the auto - manual mount? i got that from hasport. also thanks for the help
Old Oct 29, 2007 | 01:01 PM
Luserkid's Avatar
Auto to manual mount only works for hydro trans. It wont sit on the cable trans (i believe its the bolt pattern thats the problem), thats why you need a special auto to manual cable trans mount.
Old Oct 29, 2007 | 01:08 PM
sicones's Avatar
it's not worth it, selling the tranny and getting a new one (time+costs) will probably end up being easier then doing that stupid swap
doesn't that tranny also use a cable driven VSS
Old Oct 29, 2007 | 02:16 PM
Luserkid's Avatar
Default Re: need a lil auto to manual help... (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">doesn't that tranny also use a cable driven VSS </TD></TR></TABLE>
Yes but electrical VSS will bolt right up.
Old Oct 30, 2007 | 05:00 AM
miguel329's Avatar
ok thanks guys i think im going to go with a gsr with a fatory lsd
1.5boosted
Dec 13, 2007 11:13 AM
dem0nk1d
Aug 15, 2007 12:30 PM
zx9rbart
Nov 7, 2006 09:27 AM
itsmike
Jun 20, 2006 10:32 PM
drkblue_civic
Jun 8, 2002 02:38 PM
