Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
03 Accord Headlight adjustment????
Old Oct 28, 2007 | 09:56 PM
Danger69's Avatar
Default 03 Accord Headlight adjustment????
I took my whole headlight out and I do not see where there is a gear to adjust the low beam. It just has an empty hole. I even tried the other gear that I thought would move the hi beam and that doesn't move anything as well. Any help would be appreciated.
Old Oct 30, 2007 | 12:37 AM
alwayshi's Avatar
Default Re: 03 Accord Headlight adjustment???? (Danger69)
I have the same problem. I need to adjust my lights too, but can't figure out how to do it. Any help would be appreciated.
Old Oct 30, 2007 | 12:40 AM
Twixle's Avatar
ate my pixel
Default Re: 03 Accord Headlight adjustment???? (alwayshi)
I don't know the 03 inside and out, but there should usually be an extended screw that you can loosen or tighten to move the headlight up/down.
The adjustment for the headlight is going to be connected to the radiator support, not in the headlight itself.
Old Dec 16, 2008 | 11:00 PM
agoon_911's Avatar
Well! You've got to use a phillipe (+) screw driver make sure it's about 9inch long. Now open up your hood. Right next to the headlights there's a hole it's got ARROW+ and ARROW-. You may require a flashlight if you are adjusting your headlights at night, I preffer at night because it's easier to see your beam on a wall. Speaking of wall, you should park your car facing a wall about 5-10 feet away. when you put the screwdriver in through the whole make sure the knots match with the white **** on the headlight. It will take a while for you to see the difference...
I've done it so many times... but my passenger side light does not match with it's highbeam. There's about 9 degree difference between the lowbeam and the highbeam...
Old Oct 24, 2009 | 09:53 PM
deadlydingo's Avatar
New User
Can you post a pic of this by chance? I couldn't get it to work. I'm only seeing one hole with the geared screw to turn (the one closer to the front on the plastic that has an "A" next to it), and that one isn't really doing anything. I can't find another screw to turn.
Old Oct 28, 2009 | 02:43 PM
D_Rawker's Avatar
New User
is there a diagramfor that...likepictures or anything...imhaveing that sameprobem right now
04TYPEsaggin
May 12, 2008 04:11 PM
Fuster_Cluck
Feb 24, 2007 11:19 AM
mickey513
Mar 26, 2003 08:30 AM
