Which IC piping kit?
Old Oct 28, 2007 | 07:53 PM
wernhersey's Avatar
Default Which IC piping kit?
I am going to buy a cheap ebay IC piping kit to boost my DA but I don't know what bends I will need. Can anyone give me an estimate of the different pipes I will need. I don't want to order a kit that I can't use. Thanks
Old Oct 28, 2007 | 08:48 PM
DESTROYER's Avatar
Look at racing-solutions website, they have a kit you can use. What parts you use is up to the fabricator aka YOU. I have a certain style for building IC pipes, as will the next shop, it's all about preference.
Old Oct 28, 2007 | 09:03 PM
LordAphotic's Avatar
everyone talks **** on ebay...
and not to cheap out.... but thats cause they dont know why parts fail and they dont know where they can cheap out... so they just generalize it.
I got a intercooler and piping kit with couplers from ebay and it worked great.... it was a universal kit too but it had enough angles to complete the whole kit.
the intercooler will not flow as well as a namebrand or percision crafted ones but it will defitnatly get the job done.
Old Oct 29, 2007 | 07:08 AM
wernhersey's Avatar
Default Re: (LordAphotic)
[QUOTE=LordAphotic]everyone talks **** on ebay...
and not to cheap out.... but thats cause they dont know why parts fail and they dont know where they can cheap out... so they just generalize it.QUOTE]
I totally agree with this! But I don't have enough turbo experience to know what ebay parts to stay away from. Thanks guys
Old Oct 29, 2007 | 11:46 AM
spiceisler's Avatar
Default Re: (wernhersey)
Get one from these guys Just Intercoolers
The guage of their pipes are pretty thick and the aluminum is a good quality. In addition the pipes are beaded on both ends.
Old Oct 29, 2007 | 12:44 PM
big pete's Avatar
Default Re: (spiceisler)
Slightly OT: I picked up one of the piping kits off ebay and chopped it up for my Miata. Do I need to weld some beads on where the piping meets the coupler or am I good as is?
Old Oct 29, 2007 | 01:13 PM
RynoDyno312's Avatar
Default Re: (big pete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big pete &raquo;</TD></TR><TR><TD CLASS="quote">Slightly OT: I picked up one of the piping kits off ebay and chopped it up for my Miata. Do I need to weld some beads on where the piping meets the coupler or am I good as is?</TD></TR></TABLE>
I'm running a hair under 10psi peak through non-beaded aluminum piping that I got on ebay. You should be fine with a nice tight t-bolt clamp.
I have also heard that spraying the ends of the pipe with hairspray where the coupler goes on helps keep the pipes together, but I haven't had any blow off yet so I haven't tried it.
Old Oct 29, 2007 | 08:53 PM
big pete's Avatar
Default Re: (RynoDyno312)
mucho gracias amigo I'm probably going to run 10-12psi's
Old Oct 30, 2007 | 08:00 AM
BoostCoupe's Avatar
i've been running a chop and fit kit on my dd at 11psi and it's doing fine. looking to get this kit. it replicated the spoolin kit and is offered for different chassis. less couplers to blow off and bead rolled ends. 130shipped. http://cgi.ebay.com/ebaymotors...wItem
Old Oct 30, 2007 | 12:51 PM
wernhersey's Avatar
Default Re: (BoostCoupe)
I would like to have something like that but for a DA.
Old Oct 30, 2007 | 06:59 PM
CodyC142's Avatar
how close is the set up for a 92-95 civic compared to a DA? I know everything from the egs is basically compatible with the dcs. Wasnt sure if this kit would match up on the da.
Best of luck suckah
p.s. your da didnt beat an A4..
soo..
Old Oct 30, 2007 | 11:59 PM
IceySC's Avatar
Default Re: (CodyC142)
im trying to find a piping kit with 2.5 all the way around some thing i dont have to cut and make it fit..anyone know of any????
Almighty-Si
Feb 20, 2013 08:42 PM
Nikademo
Apr 21, 2010 06:02 PM
LSej1
May 22, 2008 12:44 PM
Panoply
Oct 5, 2006 03:48 PM
redDAinteg
Jan 15, 2006 02:45 PM
