has anyone past emissions with a test pipe???
Old Jun 21, 2002 | 09:11 PM
SPOON_BeIgHtEeNsEe's Avatar
Default has anyone past emissions with a test pipe???
im gonna be going to emissions soon and need to know if anyone has past emissions with a test pipe on??? sold my cat awhile back... and i dont wanna spend money on a dumb cat... but if i have too i guess i gotta then
Old Jun 21, 2002 | 09:12 PM
DR. ON POINT's Avatar
Banned
Default Re: has anyone past emissions with a test pipe??? (SPOON_BeIgHtEeNsEe)
no u will not pass, to bad u dont "know" people to help u out
Old Jun 21, 2002 | 10:41 PM
underrated99si's Avatar
Default Re: has anyone past emissions with a test pipe??? (On Point EK!!!!!!!!)
Looks like you are buying a cat as a cat is what helps cut down emissions and a inspector will fail you flat out if he sees not cat
Old Jun 22, 2002 | 04:38 AM
94CivicSi's Avatar
Default Re: has anyone past emissions with a test pipe??? (underrated99si)
I've got a Carsound 94006 Hi-flow cat, CARB legal, I can sell you. It's brand new, in the box. I got it for $95. I'll give it to you for $75 shipped if you're interested.
Nate - iamn8@hotmail.com
Old Jun 22, 2002 | 03:26 PM
SloVXHatch's Avatar
I have 2 cats for sale. One is a tabby the other is a manx. Both will pass inspection. IM me for more info.
Old Jun 22, 2002 | 03:40 PM
Default Re: has anyone past emissions with a test pipe??? (94CivicSi)
will that cat bolt up to a 2.5 collector???
Old Jun 22, 2002 | 03:41 PM
turboman's Avatar
Default Re: has anyone past emissions with a test pipe??? (SloVXHatch)
I think you can pass. You would have to really lean out the fuel. Last time I took my car for inspection it came out with "0" emissions. I lowered the fuel pressure and turned down the amount of fuel it used.
It should make for a more complete burn but not motor friendly so it's is just to make it pass.
Don't yell at me if it doesn't work for you though. I'm just saying it worked for me once. Now I just kinda get the sticker no questions asked. ssshhh
Old Jun 22, 2002 | 04:23 PM
lucas569's Avatar
Default Re: has anyone past emissions with a test pipe??? (turboman)
i passed here in ct BUT the nos or nox portion did not pass, thats the test they use to SEE IF you actually have a cat (or bad cat) couple yrs ago when they didnt test for that my car would have passed no problem.
Old Jun 22, 2002 | 05:55 PM
rodrez.'s Avatar
Default Re: has anyone past emissions with a test pipe??? (lucas569)
I almost passed w/out a cat on my old car. It had a B16 w/a stroker kit, TypeR cams, intake mani, throttle body etc. The shop would pass me on the visual, but the car wouldn't pass by the numbers, he said it was extremely close, just a tad over the limit, so I went to Kragen and picked up a cheap cat for 50 bucks, threw it on and passed.
Old Jun 22, 2002 | 06:07 PM
Default Re: has anyone past emissions with a test pipe??? (rodrez)
DAMN i dont wanna buy a damn cat... o well... anyone have one for sale??? i need one that will fit onto a 2.5 collector...
Old Jun 22, 2002 | 08:50 PM
cvcc721's Avatar
retard timing, set valves to loose end, change oil if needed, check spark plugs, check cap and rotor, check spark plug wires, dump in some "guaranteed to pass" fuel additive, and as a last resort... Two bottles of 90% rubbing alcohol. Good luck!
Old Jun 22, 2002 | 09:07 PM
nema741's Avatar
Default Re: has anyone past emissions with a test pipe??? (cvcc721)
I'd suggest the Guaranteed to Pass fuel additive, it works really good lol,
Old Jun 22, 2002 | 09:10 PM
HatchBox's Avatar
Skoobie no more...
Default Re: has anyone past emissions with a test pipe??? (nema741)
were can i get this...
Old Jun 23, 2002 | 03:31 PM
bronzeJDMhatch's Avatar
i passed with a Spoon test pipe...then again i had to pay $100 to pass LOL
Old Jun 23, 2002 | 05:57 PM
Mike P.'s Avatar
25 Year Member
Default Re: has anyone past emissions with a test pipe??? (xxkenyon419xx)
right on the shelf next to "GLH" (Grows Like Hair for men)
brandobot89
Jun 26, 2008 10:22 PM
AK94GSR
Aug 8, 2002 08:28 PM
ezark
Jun 21, 2002 10:12 AM
Mr. Vapor
Oct 17, 2001 08:35 AM
