Clutch problem? need help
Old Oct 28, 2007 | 07:34 PM
Si93_22's Avatar
Default Clutch problem? need help
Hey guys, my 93 si is having a problem. One of my buddies drove it and now i cant change gears. i can step on the clutch and turn on the car but i cant put it to first or any other gears. the car is bone stock not sure what clutch cause i just got it and they told me they just put in a new one. Any info would help thanks !
Old Oct 28, 2007 | 09:31 PM
racer181's Avatar
Default Re: Clutch problem? need help (Si93_22)
try starting your car in gear. If it lurches then your clutch isn't disengaging. I've had 2 clutch go out on two different preludes. I believe a spring popped outta the disc
Old Oct 28, 2007 | 10:40 PM
hott95ej2's Avatar
Default Re: Clutch problem? need help (racer181)
check to see if your clutch master cylinder or slave cylinder is bleeding down before assuming the clutch is gone.
Old Oct 28, 2007 | 10:44 PM
Si93_22's Avatar
thanks guys, but i forgot to mention that when i step on the clutch it is very loose, not stiff at all,
Old Oct 28, 2007 | 11:08 PM
racer181's Avatar
could have an air bubble in the slave cylinder line or outta/low on fluid.
Does your pedal pop back normal or does it stick to the floor
Old Oct 29, 2007 | 08:43 AM
Si93_22's Avatar
It sticks to the floor and doesnt come back up
Old Oct 29, 2007 | 08:50 AM
CRX T-Si's Avatar
If the pedel sticks to the floor then you better check your clutch fluid.
You might have a leak in the line or very little fluid left.
Also check with your friend if he do anything to the car.
Old Oct 29, 2007 | 08:59 AM
Si93_22's Avatar
Default Re: Clutch problem? need help (CRX T-Si)
where is the clutch fluid at ? so i can check? thanks guys
v8killaz
Dec 9, 2009 08:58 AM
AllMotorRP
Honda S2000
Mar 23, 2009 07:41 PM
hatchsi0485
Nov 21, 2005 06:13 AM
xiztence
Nov 10, 2005 01:37 PM
OSG 97 ITR
Apr 17, 2004 10:11 AM
