Bad Vibration when turning? Help ASAP!
Old Jun 21, 2002 | 08:51 PM
OneScarySOHC's Avatar
Default Bad Vibration when turning? Help ASAP!
Im working on a 92-95 civic with a 94 GSR swap. Every time the car turns to the right there is a VERY bad vibration. Turning left it does not vibrate at all. We just finished changing out the CV axle with a new one, and its still doing the same thing, so we know its not that. What else could it be?
When the axle was out, we looked into the tranny, and the teeth inside the tranny in the open diff, moved up and down... is this normal? Or could the diff be shot?
Any suggestions you all can give would be appeciated!
Old Jun 21, 2002 | 09:12 PM
JDMvtecDRAGSTA's Avatar
Default Re: Bad Vibration when turning? Help ASAP! (OneScarySOHC)
make sure the lugnuts are tightnened
Old Jun 21, 2002 | 11:15 PM
Default Re: Bad Vibration when turning? Help ASAP! (sohcmydohc)
Please do not take me for a moron because I definitely am not one... anyone with some serious comments?
Old Jun 22, 2002 | 08:44 AM
wtf i am serious.
that was the case with my friend one time.
just remember if you have some problems it could be something as simple as that sometimes ppl forget to do the little things
Old Jun 22, 2002 | 12:35 PM
.nate's Avatar
Trust me we havent. Its not as if the wheel is bent or somethingeither because we've tried different wheels. Anyone?
Old Jun 22, 2002 | 05:47 PM
VWkila's Avatar
Default Re: Bad Vibration when turning? Help ASAP! (TheFLY)
Check the hub bearings. When you have bad hub bearings, it will make clicking sound. But I don't know it will vibrate.
I don't think it's the gearbox problem. If it was the gear box, it should be constant. Unless it's the LSD. Did GSR come with LSD?
Old Jun 22, 2002 | 06:59 PM
Russ713's Avatar
dAng!
Default Re: Bad Vibration when turning? Help ASAP! (VWkila)
cv joints
Old Jun 22, 2002 | 07:09 PM
Kamin's Avatar
Default Re: Bad Vibration when turning? Help ASAP! (Black Light)
hey dont take that lug nut thing for granted
there are people on here who have forgotten to tighten them.
nobodys perfect, everyone forgets simple things.
i would bet my 1$ on an axle related problem.
check the cv boots.
Old Jun 23, 2002 | 10:21 AM
.nate's Avatar
Default Re: Bad Vibration when turning? Help ASAP! (KAMiN)
I just put new axles in, and its still doing it, so I know its not that.
The car does not have a LSD it has a open diff.
I have a power steering race with the PS removed (no fluid in the rack). Anyway could it be something with the rack?
Old Jun 24, 2002 | 06:01 AM
.nate's Avatar
*bump*
Old Jun 25, 2002 | 08:23 AM
.nate's Avatar
Default Re: Bad Vibration when turning? Help ASAP! (N8)
Transmission & Drivetrain
Feb 7, 2010 07:34 PM
hondateg91
Honda Civic (2001 - 2005)
Jun 10, 2009 05:20 PM
spets
Suspension & Brakes
Apr 5, 2008 05:31 PM
SteelCityKid
Aug 11, 2001 07:33 PM
