Replacing Alternator / 1995 LS
Old Oct 28, 2007 | 01:34 PM
tkewtn's Avatar
Default Replacing Alternator / 1995 LS
Does anyone know how to replace an alternator?
How many bolts are there to remove?
Do I have to take out the axle?
If you have any pictures that go along with instructions that would be great too
Old Oct 28, 2007 | 02:12 PM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Default Re: Replacing Alternator / 1995 LS (tkewtn)
you don't have to take out the axle.
You can get it out from the bottom if you take out the frame brace bar (not sure if thats the official term for it)
I think it's 2 bolts. One of them is used to set the tension on the belt.
Old Oct 28, 2007 | 04:25 PM
jsweet's Avatar
If you jack it up, remove the driver's side wheel, and remove the big plastic under-tray, you can access the lower bolt (that the alternator pivots on). Then, from up top, remove the bolt that is used to adjust the tension and you should be able to remove it out of the bottom.
Old Oct 30, 2007 | 09:20 AM
tkewtn's Avatar
Thanks guys appreciate it
Got that sucker out
Old Oct 31, 2007 | 08:10 AM
maximumcarnagetc's Avatar
hey guys, im new here but have a similar problem. i have a 1987 integra ls. my alternator went out and i want to replace it. how do i go about doing that? is it the same steps as the 1995 ls?
TnC
Jan 27, 2011 12:13 PM
--eclipse--
Jun 18, 2007 08:55 PM
shiux
Oct 22, 2005 09:30 AM
Layziebtnh055
May 3, 2004 12:07 PM
Shft@9GSR
Nov 23, 2002 08:05 PM
