timming belt help please
Old Oct 28, 2007 | 12:01 PM
B18C5_VTEC's Avatar
Default timming belt help please
hi, i have a b18c5 and i was changing the timing belt and was having some issues. when ever i put the timing belt on it ends up moving just a little. first i lined up the crank with the tdc mark and then the cam gears with their marks then put the belt on. after i turn the motor three teeth, i tighten the tennstioner and rotate the motor six times, and it ends up being a little off everytime. any help would be very helpful, thanks.
Old Oct 28, 2007 | 11:40 PM
typeR#0427's Avatar
Default Re: timming belt help please (B18C5_VTEC)
what is off? the alignment of the TDC marks, or the tension of the belt?
Old Oct 31, 2007 | 07:13 PM
B18C5_VTEC's Avatar
the alignment of the tdc marks
Old Oct 31, 2007 | 07:50 PM
typeR#0427's Avatar
Default Re: (B18C5_VTEC)
i think your supposed to turn the crand 5-6 times, then tighten the tensioner, then move it forward 3 teeth.
are you working from a shop manual?
Old Oct 31, 2007 | 08:00 PM
typeR#0427's Avatar
ok,from the honda manual:
after lining up the TDC marks, install timing belt
1: crankshaft
2: adjusting pulley
3: water pump pulley
4: exhaust camshaft pulley
5: intake camshaft pulley
loosen and retighten the adjusting bolt to tension the belt
rotate crankshaft about 4 or 6 turns counter clockwise so that the belt postitions on the pulleys
adjust timing belt tension:loosen the bolt 1/2 turn, rotate crankshaft counter clockwise 3 teeth on the pulley tighten adjusting bolt
check the crankshaft pulley and camshaft pulley at TDC
i had some trouble with mine to just be patient
Old Oct 31, 2007 | 09:23 PM
BMaDOHC's Avatar
Default Re: timming belt help please (typeR#0427)
that sounds way harder then the common way at the dealership. line all your marks up, install a couple screwdrivers in the holes up top to hold the cams straight, put belt on starting with the front of the motor leaving all slack in the back on the tensioner, push tensioner with finger pressure until slack is gone and tighten 14mm on tensioner. done.
Old Nov 1, 2007 | 09:18 AM
typeR#0427's Avatar
Default Re: timming belt help please (BMaDOHC)
yes those cam lock tools sure would be a good investment, i was just copying right from the service manual
Old Nov 1, 2007 | 10:11 AM
totsie7944's Avatar
you guys all make it waaay to hard. Just take a wire coat hanger, get it in the hole on the tensioner where the spring is...pullup with some force until the belt is good and tight and you or someone else tighten the 14mm bolt.
The belt will be slightly off at the crank no matter what you do..unless your off by a tooth on the cam gears, which if you do it right and tension properly you won't be, you will have no issues.
Old Nov 1, 2007 | 10:19 AM
all-mtr-teg's Avatar
Default Re: timming belt help please (totsie7944)
That's how i do mines
Old Nov 1, 2007 | 10:52 AM
Ed 341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">you guys all make it waaay to hard. Just take a wire coat hanger, get it in the hole on the tensioner where the spring is...pullup with some force until the belt is good and tight and you or someone else tighten the 14mm bolt.
The belt will be slightly off at the crank no matter what you do..unless your off by a tooth on the cam gears, which if you do it right and tension properly you won't be, you will have no issues.</TD></TR></TABLE>
Worked for me.
Old Nov 1, 2007 | 11:56 AM
Utilitarian's Avatar
That's exactly what I found when I did mine. I tried the Helm's way two times and the belt jumped a tooth or two each time. I was soooo pissed and had to realign each time.
Coat hanger ftw
Old Nov 1, 2007 | 10:38 PM
typeR#0427's Avatar
Default Re: timming belt help please (Utilitarian)
sorry, i was just reading the service manual, i think i did the coat hanger too, just wanted to give accurate advice.
i was so tired when i was at that point i dont remember anything.
Old Nov 2, 2007 | 09:18 AM
B18C5_VTEC's Avatar
allright thanks for all the help. i have tried all those ways already, even the coat hanger. but i will try agian today, and will tell u if i have any luck. thanks.
ryanevansoh
Apr 22, 2009 08:51 PM
bigizsosexy
May 21, 2008 03:13 PM
98GSR-Turbo
Feb 11, 2008 02:14 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
DA-MAX
Jan 25, 2003 03:48 PM
