autolock help
Old Jun 21, 2002 | 07:46 PM
d8168055's Avatar
Default autolock help
to those how have it, when installed, does it still wiggle a little? cant seem to make it tite... pic would be helpful, thanks
Old Jun 21, 2002 | 08:01 PM
NXSpoon's Avatar
Default Re: autolock help (d8168055)
Yeah, mine wiggles a bit on my Si, but I tried and tried...."it ain't coming off"
BTW, right now I am using it on the brake pedal, tomorrow I will try it on the clutch.
Old Jun 21, 2002 | 08:21 PM
SurferX's Avatar
Default Re: autolock help (NXSpoon)
Mine wiggles a little, but it's okay it's not going to come off. Using it on the brake especially in an MT is totally useless. They can still drive the car all they need to do is use the hand brake, my mom did this for months when her brake pads were gone. I'd definitely put it on the clutch.
Old Jun 21, 2002 | 08:30 PM
Satin Si's Avatar
Mine wiggles too, i can only put it on the brake pedal, won't fit the clutch.
Old Jun 21, 2002 | 09:06 PM
d8168055's Avatar
Default Re: autolock help (SurferX)
SurferX, yes.. i agree w/ u... but it seems kinda wierd that it wiggles...
Old Jun 21, 2002 | 09:22 PM
SurferX's Avatar
If you get it at the right angle, you will be able to tighten it far enough to catch that last locking tooth so it's all tight. Sometimes I get it super tight and sometimes I just can't catch that last tooth. Either way I don't see it being any more or less effective.
Old Jun 21, 2002 | 09:26 PM
nfn15037's Avatar
WTF?!? You let you mom drive around like that for months? Goddamn man
Old Jun 21, 2002 | 09:47 PM
TeamTooQuick's Avatar
Default Re: autolock help (nfn15037)
mine wiggles a lot, but i tried and tried it wont come off, and the clutch cant be pushed down. But i seen on a TV once them shooting it and only a chip of it came off, i was like damn. But i put mine on the clutch, kinda hard because that dead foot rest but make it work ....Autolock=
Old Jun 21, 2002 | 10:07 PM
underrated99si's Avatar
Well on my SI I can get it tight and strait up but on the ITR I have been driving for last 2 days I get it tight but is still hangs down a bit and moves. I have tried to make it fit perfect but it does not but still does its job. DOnt wory
Old Jun 21, 2002 | 10:10 PM
Type Goch's Avatar
New User
It would wiggle just a slight bit but not so much that it'll wiggle more than an inch. Mine helped prevent my car from being stolen...
Old Jun 21, 2002 | 10:15 PM
Default Re: autolock help (Type Goch)
mine wiggles way more then an inch. Its not even close to being tight
[Modified by TeamTooQuick, 7:15 AM 6/22/2002]
Old Jun 21, 2002 | 10:16 PM
GokuSSJ4's Avatar
on some cases , hand brake is not enough to stop the car
jxhxb
25
Dec 7, 2007 07:00 AM
laocivic
Sep 8, 2007 06:45 AM
Ph0eNix
Nov 7, 2002 01:07 PM
