H.I.D
Old Oct 28, 2007 | 01:17 AM
95civiccpdx's Avatar
Default H.I.D
4300K / 6000K / 8000K / 10,000K HID XENON KIT
does anyone know which one is brighter????
Old Oct 28, 2007 | 01:29 AM
cb7tougeracer's Avatar
Default Re: H.I.D (95civiccpdx)
my guess would be 10,000k
Old Oct 28, 2007 | 01:37 AM
no_money2supe's Avatar
They're all just as "bright." It's not the K's the measures a light's "brightness," but rather its lumens. The K rating is simply the colour output of the light (4300K is OEM, 6000K is OEM w. bluish tint, 8000K is bluish purple, 10,000K is you're a complete moron - who in their right minds would do that purple).
Now, if you are asking about glaring the heck out of the opposing driver or the person in front of you, then the above poster has it correct, that would be the 10,000K HID.
Old Oct 28, 2007 | 02:12 AM
BlueIntegraBoy's Avatar
4300k has the most lumens
Old Oct 28, 2007 | 06:46 AM
Razr2's Avatar
Default Re: H.I.D (BlueIntegraBoy)
Yea 4300k puts out the MOST usable light. If you wanna be "cool" and have that bluish tint, get 8k. Although, 4300-6k are most functionable.
Old Oct 28, 2007 | 07:20 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: H.I.D (Razr2)
Sounds like you're getting a "plug and play" kit.
If your hid's aren't out of a junk car then your light will suck regardless of the "kelvin" of the output.
Old Oct 28, 2007 | 07:27 AM
Eran's Avatar
HT White Ops
What a lot of you are missing is the inverse relation between kelvins and lumins.
The higher the kelvins, the lower the lumins. So technically, if you had an equally powered light source that would put off light at 10 kelvins, it'd have a **** TON of lumins ... you just wouldn't be able to see them, because they'd be infra red/violet.
4300K is the ideal color temperature. It puts off the truest white light and provides the most without distorting color or losing depth. Any more yellow, you lose contrast. And more blue, and you start getting dimmer.
Old Oct 28, 2007 | 09:45 AM
EK_B's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">What a lot of you are missing is the inverse relation between kelvins and lumins.
4300K is the ideal color temperature. It puts off the truest white light and provides the most without distorting color or losing depth. Any more yellow, you lose contrast. And more blue, and you start getting dimmer.</TD></TR></TABLE>
I love you Eran.
Old Oct 28, 2007 | 09:56 AM
pynikal's Avatar
Default Re: (EK_B)
function=4300k
rice=10,000k
you choose.
Old Oct 28, 2007 | 09:57 AM
Eran's Avatar
HT White Ops
Default Re: (pynikal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pynikal &raquo;</TD></TR><TR><TD CLASS="quote">function=4300k HID retrofit
rice=3000K - 20000K HID Plug 'n' Play
you choose.</TD></TR></TABLE>
Fixed that for you.
Old Oct 28, 2007 | 10:00 AM
ke98248's Avatar
Default Re: (Eran)
What's the advantages of an HID retrofit vs plug N play?
Old Oct 28, 2007 | 10:04 AM
Eran's Avatar
HT White Ops
Default Re: (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 &raquo;</TD></TR><TR><TD CLASS="quote">What's the advantages of an HID retrofit vs plug N play?</TD></TR></TABLE>
HID retrofits involve installing HID-optic projectors into your stock headlamp. These projector housings were designed specifically for the amount of light put out by a D2S HID bulb. Properly installing a HID retro will give you a perfect cutoff and maximum efficiency in light output.
Plug 'n' Play kits are rebased D2R bulbs that are installed in a stock halogen reflector housing. These kits are generally poorly made, and the light put out by them overpowers the stock reflector. This causes a poor cutoff, glare, hot spots / cold spots, and a generally unpleasant environment for you and everyone else on the road.
Old Oct 28, 2007 | 10:06 AM
ke98248's Avatar
Default Re: (Eran)
Thanks!
Old Oct 28, 2007 | 10:41 AM
skcivic4life's Avatar
http://stores.ebay.com/HID-Outdoor-Equipments
i have some friends that have bought from this store and they love them, i'm going to be buying some from them for my civic and for my daily driver.
i can post up pics comparing my buddies lights if u want, its on an sonoma but still shows the difference.
he got 6,000k
Old Oct 28, 2007 | 11:05 AM
pynikal's Avatar
i had a 4300k plug and play kit in my eg and at first there was alot of "scattering" of the light and i emailed the place that i got them and they suggested a shield for the light that goes around the bulb and after i installed that there was a very straight blunt line were the lights cut off. forgot the name of the shelid but it worked great!! but i do agree if you are going to go HID do a retrofit. that is just my experince with HIDs.
Old Oct 28, 2007 | 05:38 PM
knuckk's Avatar
4300k ftw!
Old Oct 28, 2007 | 06:31 PM
TURBODC4TEG's Avatar
Default Re: H.I.D (cb7tougeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7tougeracer &raquo;</TD></TR><TR><TD CLASS="quote">my guess would be 10,000k</TD></TR></TABLE> lol nope
DAlexsanderC
Mar 17, 2011 06:36 PM
rainmanef
Jul 15, 2008 11:14 PM
G_seven
Acura TSX
28
Apr 4, 2008 11:11 AM
SlamminS85
Nov 20, 2005 05:56 PM
hobo79
Jan 16, 2004 09:23 PM
