turbo xs rfl bov not opening
just installed my turbo kit, everything is running fine except for the bov which is not opening for some reason. i T it off the fuel pressure vacuum line which is also the source to my WG. is it not opening because i have too many sh*t off the same source???? i am also not using and washers to preload the bov, but that thing still not opening
you have way too much on a small vac source. get a manifold or use the booster vac source or run individual.
is it me or is this like the 4th bov vac question tonight?
