Is my BOV vacuum line connected correctly?
Is My BOV vacuum line connected to the correct place? It never seemed like it worked, i thought it worked at first but it was juss some flutter coming out of the turbo ,
if my vacuum lines are connected correctly, then i will be picking up a LEGIT HKS BOV and installing it, another question, i can just take off my existing Replica SSQV and use the same flange and install the HKS one right?
Re: Is my BOV vacuum line connected correctly?
try to tie into anouther port other than the fuel pressure vacuum line...I use the PCV intake port for the the bov vacuum and ditch the pvc system and upgrade to new valve cover ports and the back of the block for the PCV
Whats so bad about that BOV guys???/ foreal
and BTW i would use a stronger vac. source In all my turbo builds iv always Tee'd off the brake booster vac....
its a crappy BOV, because its probably one of those ebay ones,
ima pick up a real HKS BOV today and hopefully it works, if not i will try a different vaccum.
and i ziptied the injector as a temporary fix, it sounded like a subaru before due to misfire, cus that injector was loose
ahhhh man Ebay BOV's are JUNK lol srsly they break SO dam easy and im just playin with ya on the zipties,,,,shyt i wish i woulda thought of that when i broke one of the plugs off my turbo ls integra
No, not hooked up correctly. You need to be using a different source. The fuel pressure vac line is ESSENTIAL to you getting enough fuel to the engine, it should be dedicated. If that line comes off or breaks you are going insta-lean in boost.
Picked up a hks SSQV, works like a charm, no flutter, juss a cleann kACHUUUUUUUUU
and as for the fuel line vacuum, i never thought of that,
what should i use for the bov as a vacuum?
PVC would be fine, it's been a while since I've actually had a PVC on my Dseries, but that IM has two big nipples on the front of it that you could T from.
Either that or you can get yourself a vacuum block.
Jerry, you're fine. Just make sure the hoses on the T-Fitting doesn't come off. Your vacuum source will work, but there are better ones. It is hooked up correctly, but you could have chosen a better vacuum source. If it works, don't change it.
for sure LOL, the T fitting is actually pretty tight, it was actually a bitch to pull it off, and dude i was in GG again at volcano tea, then got some 50% off pho at some 24hour pho place, YEE
Can i Run a direct line from that other nipple to the bov thats covered by the rubber cover? in the picture next to the throttle cable,
Should have hit me up, sounds good! If its working, why do you want to relocate it? You aren't boosting much, are you?
oh its just that one guy who said i should have a independent vacuum to the fuel, instead of sharing it with the BOV, nope 7.5 lbs, will go higher in the future when i get some vitara pistons and stuffs xP
