over heat problems?!!?!
Old Oct 27, 2007 | 07:09 AM
iiv3's Avatar
Default over heat problems?!!?!
hello to everyone....
my question is about my 96 ex with a si swap i just got it last week and already problems... the coolant looks like its leaking from the radiator core also the fan wont turn on however it looks like the thermostat is working becuase i knowits overheating.. any ideas no where to start to fix these problems and how much it would cosT?
Old Oct 27, 2007 | 07:14 AM
95ProjectEJ1's Avatar
Default Re: over heat problems?!!?! (iiv3)
Is it leaking from the radiator itself? If so you would want to replace the radiator. Make sure none of the hoses are leaking also.
If you feel the fan isnt working than you can start your car in the driveway and let it sit for 15-20 mins while you keep an eye on the temp. If it doesnt work in that time period come back and I'll give you a couple things to do in order to test the fan itself, thermoswitch and relay.
Radiator - $100 from Autozone
Thermostat - $20 est. from Honda - slhondaparts.com hondapartsdeals.com
Thermoswitch - $20 est. from Honda
Relay - $40-60 from Honda
Old Oct 27, 2007 | 07:15 AM
1992Si's Avatar
Get a new radiator first. You need to stop the leak.
Old Oct 27, 2007 | 07:20 AM
iiv3's Avatar
sorry not the radiator the heater core***
and the fan doesnt turn at all i had to drive from jersey to NY last night a usual 1/2 hour drive with no traffic but because of the stopping so the motor dont overheat and die it took me 4 hours
Old Oct 27, 2007 | 07:24 AM
Default Re:
Once you replace the radiator you will want to "burp" the system.
1. Pop your hood and remove your radiator cap
2. Start up your car and let it idle for 15-20 mins
*You should see bubbles coming from the neck of the new radiator you install. During this time frame the fan should activate, if it doesnt then you will want to...
3. Cut two pieces of wire long enough to reach from your battery to your OEM fan connector on the fan shroud.
4. Connect 1 wire from the "+" battery terminal to the "+" connector prong. Do the same for the "-". This will "jump" the fan. If the fan doesnt come on, then your fan is bad also. Put the connector back on.
5. Now grab a paperclip and locate your thermoswitch on your thermostat housing. Its should have a brown connector tip and be brass in color. Remove the connector and put each end of the paper clip into the female ports of the connector you just removed. You should hear a click and the fan should activate if #4 shows that your fan is good. If you hear a *click* and the fan turns on then your relay is good and the thermoswitch is bad (based on #2 telling us the fan didnt activate)
FoRizzyy
Jun 5, 2012 06:53 PM
NickyB92HCivic
Oct 17, 2010 10:49 AM
JDM_Silver
May 30, 2007 09:03 AM
CTara12345
Sep 15, 2005 12:31 PM
envious1320
Mar 9, 2003 04:50 PM
