Smog in Two Months
Old Oct 26, 2007 | 11:24 PM
kphamx's Avatar
Default Smog in Two Months
I gotta smog in two months or my tags are gonna expire. The problem is is that i'm running a B16a2 without o2 sensors and cats. as of now i think i'm shooting out a decent amount of smoke and the old owner that i bought it from says it has stage 2 cam gears but that is unverified. as this point i realized i probably need two o2 sensors and two cats possibly. would i need anything else or anything else i should worry about. the b16 is eating a lot of oil or its leaking from somewhere... thanks for the help.
Old Oct 27, 2007 | 01:56 AM
john666's Avatar
Default Re: Smog in Two Months (kphamx)
what car is ur b16 in ? u should probably go find a buddy that knows someone that gets things done.
Old Oct 27, 2007 | 07:46 AM
Bazza's Avatar
buy a new motor....... if your eating/leaking that much oil you should find where its coming from b4 doing emissions... if the computer notices the least bit of oil/w.e in the exhaust its gonna fail you on the spot. second. take to a mechanic have him check out the motor...
Your prolly gonna need pistons/rings if your eatin that much oil... just a hint!.. i have to rebuild my motor cuz it was eating oil.
it sux but ya gotta do it. just go to a garage mechanic and see what he thinks.
Old Oct 28, 2007 | 12:41 PM
kphamx's Avatar
i was thinking about doing an engine rebuild too. does anyone know a rough estimate to rebuild an engine? I just had friend do one a while back, he got his head ported and a whole valve job for around 360 and the bottom block done for 600 but i forgot what was wrong with the bottom block. i think it was a bent crank or something.
wardseg6
Sep 15, 2016 08:52 AM
xlasianizelx
Aug 5, 2008 07:37 PM
spintboy
11
Feb 9, 2008 09:30 AM
Hardedge
11
Dec 5, 2007 05:21 PM
teggytegteg
May 27, 2005 11:01 PM
