reving up by itself?
Ok I just put in a skunk 2 pro intake manifold right, I connect everything how it goes, I go to start the car and it rev's up by itself like if I were hold the gas pedal down all the way.
I have someone looking into the throttle body to see if it opens up by itself and no, it's not opening up at all when I go to start it.
Just to mention I put in a b&m fpr and I haven't adjusted it yet, just mounted it on there, could that be the problem?
Also to mention, I took off and old and bended up butterfly, like where the throttle cable connect to the throttle body, to replace it with a new one, and i'm not sure if I put the spring on to tight, could that be the problem?
Please someone help!! thanks in advance
With the engine running spray WD-40 on your mani where the gaskets are and where there is any seal involved.
If there is a leak then it will suck in the liquid.
Did you install the brace in the back of the block??
smeags
10
Jul 20, 2013 10:22 AM
60019184
Jul 5, 2007 10:15 AM
White GSR '01
Jul 17, 2005 11:17 PM
