wtf!!! oil everywhere!!!!
ya i had the same exact leak two days ago replace both gaskets on ur vtec solinoid and it should fix the problem.
while your at it you can change the distributor oring just in case.
another thing you should do is clean it off with break cleaner and see if its leak from the cam plug as well. if it is replace that too.
Thats exactly where mine was leaking at and my problem was the cam seal. The dealer calls it a cam end plug though. Its a cheap and easy fix so try that before you go deeper into anything else.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">Thats exactly where mine was leaking at and my problem was the cam seal. The dealer calls it a cam end plug though. Its a cheap and easy fix so try that before you go deeper into anything else.</TD></TR></TABLE>
this is what autozone has
and ebay
Am I also gonna need the block guard??
and ebay
no ur not going to need the block guard. I would just get the two vtec solenoid gaskets first and replace those, and if that doesnt fix it totally then get the cam end plug. but just to let you know replacing the cam end plug requires u to take off the valve cover, so you would have to replaced the valve cover gasket as well. Just replace the two vtec solenoid gaskets first and go from there.
What it looks like after i replaced my vtec solenoid gaskets and distributor o-ring. (i also used some high temp silicone on that little spot on the block)
and for ***** and giggles
!? I was thinking probably the gasket but im not too sure. Any help??
