car throws constant code when jumper is put in???????
Old Oct 25, 2007 | 04:23 PM
nicko360's Avatar
* B A N N E D *
Default car throws constant code when jumper is put in???????
i have an eg hatch with an h22 swap, obd1, chipped pherable p28 ecu, but the car just throws constant code when i put the jumper in????? please help
Old Oct 26, 2007 | 06:19 PM
nicko360's Avatar
* B A N N E D *
Default Re: car throws constant code when jumper is put in??????? (nicko360)
up
Old Oct 26, 2007 | 06:41 PM
instrument's Avatar
sounds like you should be counting some blips dude.
Old Oct 26, 2007 | 06:54 PM
nicko360's Avatar
* B A N N E D *
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you should be counting some blips dude.</TD></TR></TABLE>
yeah well the light isint blinking
thats why im asking for help
im not an idiot
Old Oct 26, 2007 | 09:05 PM
nicko360's Avatar
* B A N N E D *
Old Oct 26, 2007 | 11:20 PM
nicko360's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
x2
Old Oct 26, 2007 | 11:33 PM
n1_egsex's Avatar
* B A N N E D *
do it while the car is on
Old Oct 27, 2007 | 09:27 AM
nicko360's Avatar
* B A N N E D *
Default Re: car throws constant code when jumper is put in??????? (n1_egsex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">do it while the car is on</TD></TR></TABLE>
um thats what ive been doing
Old Oct 27, 2007 | 10:01 AM
ejoner's Avatar
It stays stays on with no reaction, when jumped? Jump it then start it. Does it come on right away when you start your car un-jumped? Or does it take 5sec?. Check all of theses. Then if none of theses gives it a reaction go disconnect a sensor on the motor (tps,iacv,etc.) It sounds like a o2 code.
Old Oct 27, 2007 | 12:06 PM
nicko360's Avatar
* B A N N E D *
Default Re: car throws constant code when jumper is put in??????? (ejoner)
it throws a code in 3rd gear at 6000 rpms, when i plug in the jumper to check codes it just throws a constant check engine light. it does not flash
Old Oct 27, 2007 | 12:29 PM
89D15CRXDX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicko360 &raquo;</TD></TR><TR><TD CLASS="quote">it throws a code in 3rd gear at 6000 rpms, when i plug in the jumper to check codes it just throws a constant check engine light. it does not flash</TD></TR></TABLE>
You know what's funny? I just chipped and converted my P06 to VTEC for my D15B and it throws a constant CEL. But when I turn the key, it doesn't like up like it should. Only when I start it and rev it to any higher than 1.2K RPM. When I jumper it the CEL lights up solid red with no blips. My burned chip is working correctly because my car redlines at 8K RPM but stumbles at 7K RPM because VTEC isn't kicking it. But either way, it's still doing the same thing as yours. I sent an e-mail to Chris Harris from Xenocron so we'll see what he says and I'll post it here for you. Oh yeah, and my O2 sensor is shot so that's why it's throwing codes.
Old Oct 28, 2007 | 08:34 AM
xenocron's Avatar
Default Re: car throws constant code when jumper is put in??????? (89D15CRXDX)
If the check engine light ISNT on and you put in the jumper...the CEL light on the dash will light up SOLID.
it will only blink if you are actually throwing a code...
Old Oct 29, 2007 | 09:22 AM
nicko360's Avatar
* B A N N E D *
Default Re: car throws constant code when jumper is put in??????? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">If the check engine light ISNT on and you put in the jumper...the CEL light on the dash will light up SOLID.
it will only blink if you are actually throwing a code...</TD></TR></TABLE>
my car throws a code at the top of 3rd gear?????
but then it goes away after a few seconds??
it also seems to loose power around that time
Old Oct 29, 2007 | 06:05 PM
nicko360's Avatar
* B A N N E D *
it also seems to loose power around that time</TD></TR></TABLE>
Old Oct 31, 2007 | 06:12 AM
BIGblock97's Avatar
ECU IS PROB BAD... A SOLID CEL IS LIMP MODE
Old Nov 2, 2007 | 04:24 AM
xenocron's Avatar
Possibly, this is a Check Engine Shift Light feature...and your car is loosing power because really...it doesnt want to rev that high.
EF_ST@TUS
10
Aug 19, 2005 07:17 AM
djgalloway73
May 11, 2005 05:08 PM
THEUSED
Jan 8, 2005 03:08 AM
CivHatchH22
12
Mar 24, 2004 09:35 PM
Superdragr45
Aug 22, 2003 09:28 PM
