grinding into reverse?
i just want to get a good idea on how and why it does this. ik when mine grinds i do the 1st to reverse trick thing and it works...but what is actually going on in there to make it grind
I just had to use my new gif:
Here are some links btw:
https://honda-tech.com/zerothread?id=1520463
https://honda-tech.com/zerothread?id=783592
there is no synchro for reverse. that is why it grinds. the gears for reverse are straight cut.
the first - reverse trick aligns the shift collar and first gear which causes the mainshaft to rotate a small amount, which then causes the reverse gear to have a better chance at lining up and going in, since it is straight cut.
Another way to get reverse to go into gear is to gently let out the clutch while attempting to shift into reverse. this will cause the mainshaft to spin a small amount and allow the straight cut gears to line up better. either way works, and its best not to worry about it. the gears are really strong and can handle a little grind now and then..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeSpec »</TD></TR><TR><TD CLASS="quote">lol blinker fluid haha
just go 4th to reverse! works great</TD></TR></TABLE>
Thats what I do.
Thats what I do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dustin_Pierce »</TD></TR><TR><TD CLASS="quote">I had the same problem. So i went to the junkyard and cracked the gsr tranny from a gsr and took the reverse gear and bearings off countershaft and replaced it on mines now no more grinds.</TD></TR></TABLE>
wow.. that was a lot of pointless work dont cha think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KrenzyRyan »</TD></TR><TR><TD CLASS="quote">I just had to use my new gif:
https://honda-tech.com/zerothread?id=783592</TD></TR></TABLE>
I plan on using this gif lol. If you have any problem with that let me know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ~sp33~ »</TD></TR><TR><TD CLASS="quote">
I plan on using this gif lol. If you have any problem with that let me know.</TD></TR></TABLE>
Go for it, I made it for everyone here on Honda-tech to use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_titan »</TD></TR><TR><TD CLASS="quote">shift into first cause it's the closest to the reverse and then shift to Reverse.
what??????
i would think 4th is closest no?
</TD></TR></TABLE>what??????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n »</TD></TR><TR><TD CLASS="quote">
what??????
i would think 4th is closest no?</TD></TR></TABLE>
Lol ya, I was thinking the same thing when I read his post.
what??????
</TD></TR></TABLE>You driving a go cart?
