Oil Leaking from above Oil filter 91 Accord EX
Old Oct 25, 2007 | 02:44 PM
howzek's Avatar
Default Oil Leaking from above Oil filter 91 Accord EX
I have a 91 Accord Ex 250K. I have an Oil leak coming from above the OIl filter. Initially I thought it was the Oil Pan gaskets, but I change the gasket a week ago , its still leaking any ideas???????
Old Oct 25, 2007 | 03:20 PM
NeKe1point0's Avatar
Default Re: Oil Leaking from above Oil filter 91 Accord EX (howzek)
head gasket or valve cover gasket ... if u havent done the headgasket for awhile most likey thats it. valvecover gasket is easy to inspect/repair. Headgasket is another story.
Old Oct 26, 2007 | 10:32 AM
Honda-Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by howzek &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 Accord Ex 250K. I have an Oil leak coming from above the OIl filter. Initially I thought it was the Oil Pan gaskets, but I change the gasket a week ago , its still leaking any ideas???????</TD></TR></TABLE>
Forgive me for asking a stupid question . But if oil leak was above the oil filter why in the hell would you think that replacing the oil pan gasket would fix it ??
chk the oil pressure sending unit , it sits above the oil filter
Old Oct 28, 2007 | 12:21 AM
CBL9's Avatar
Default Re: Oil Leaking from above Oil filter 91 Accord EX (Honda-Master)
The oil pressure switch is above the filter assembly as ^^^^^^ said, they definitely start leaking as time passes.
Old Oct 28, 2007 | 07:33 AM
howzek's Avatar
Default Re: Oil Leaking from above Oil filter 91 Accord EX (CBL9)
Honda Master, as I stated in my post. INITIALY I thought it was coming from the gasket because there was so much oil. However, after I changed the gasket and cleaned the engine I could see it was coming from above the oil filter.
Yes, I know I should have clean the engine first, but I didn't, Sorry to inconvenience you by doing it in the wrong order.
Thanks to you and everyone else who replied. I will check the sending unit.
Old Oct 28, 2007 | 07:42 AM
radiuslight's Avatar
had this problem once
replaced an oil filter but when I took it off
the gasket was stuck on the engine
so when I installed the new one it would leak
r u sure its not that?
Old Oct 29, 2007 | 04:05 AM
gqstatus05's Avatar
Default Re: Oil Leaking from above Oil filter 91 Accord EX (radiuslight)
cant you just buy that dye they sell and mix it in your oil? When it leaks you'll see the color of the dye and you'll be able to determine exactly where the oil leak is coming from. does that work well?
Old Oct 29, 2007 | 08:44 AM
.</TD></TR></TABLE>
No inconvenience to me my friend ,, the inconvenience was all on your end.
I merely pointed out that it is a good idea to ALWAY diagnose first, before wasting money, time and effort , replacing unneeded parts
but I hope that it is the oil pressure switch , it is cheap and easy to replace .
Old Oct 29, 2007 | 01:46 PM
Jstall7543's Avatar
oil pressure sending unit, they crack and leak, its drips on the exhaust also!
Old Oct 29, 2007 | 04:54 PM
aries331's Avatar
Default Re: (Jstall7543)
This sounds like the oil pressure switch is the one leaking, the cost like 15 bucks.
Old Oct 31, 2007 | 02:34 PM
howzek's Avatar
Good Day Guys,
Thanks to everyone for responding. I checked the Oil pressure switch and it was cracked. I have replaced it (Cost me 10 dollars for the part) and it has not leaked since.
Thanks again for the everyones input.
JDMob
Jan 26, 2020 11:17 AM
davey5300
May 7, 2010 06:01 PM
lalonaruto
Dec 9, 2008 04:29 PM
B16CivicEX
May 30, 2006 03:15 PM
96coupe
Dec 18, 2005 01:14 PM
