FITV and its operation. If car only idles at around 1400 upon cold start should I be...
Old Oct 25, 2007 | 02:22 PM
mattsnooz's Avatar
Default FITV and its operation. If car only idles at around 1400 upon cold start should I be...
If car idles at only around 1200-1400 rpm upon cold start, should I just adjust the FITV? I'm sure its fucked but I hear I can sort of "fix" it. I would like to know more about the FITV if possible aswell.
Also, would I turn the white "screw" IN or OUT after I remove the FITV's end cap?? I believe its "in" to RAISE RPMs upon cold start, is that true?
Also, is the FITV what prevents the car from stalling out upon cold starts?? (if rpm's are too low)
Thanks again guys. This is the last outstanding issue I have with my car and its all literally perfect for a 14 year old car LOL, so help a white brother out
Old Oct 25, 2007 | 04:27 PM
mattsnooz's Avatar
Default Re: FITV and its operation. If car only idles at around 1400 upon cold start should I be... (mattsno
anybody
Old Oct 25, 2007 | 04:55 PM
royalfelix's Avatar
you have to screw it in for lower rpms...
Old Oct 25, 2007 | 05:10 PM
mgags7's Avatar
^^he's right
in to lower it
out to raise it
if you go too far out it will idle bounce
lyzer227
Feb 7, 2009 12:02 PM
seeodywhy
Sep 1, 2006 05:22 PM
ATS*Mark
Sep 28, 2005 02:37 PM
delguiner
Sep 25, 2004 01:45 PM
