stock b16 compression
Old Oct 25, 2007 | 10:18 AM
b16a95eg's Avatar
Default stock b16 compression
whats the stock compression supposed to be at? i did a test and it came out to be 180ish across all 4 cylinders. my car burns about a half quart of oil per 250 miles or so... it blows smoke out pretty bad sometimes. i changed the valve seals and piston rings but it didnt help. the smoke? any ideas of what could be wrong?
Old Oct 25, 2007 | 10:21 AM
klungemonger's Avatar
valve guides might also be worn out and a bit oversize, but there's not too much besides the things you replaced that causes burning oil. Probably your break-in procedure wasn't good, or if you had to get rough with the seals to get them on they may have been damaged.
Old Oct 25, 2007 | 11:36 AM
b16a95eg's Avatar
so the compression is good?
ewilliams1990
Jun 28, 2014 03:44 AM
MBlake55
Jul 27, 2009 04:56 PM
Brandon31386
Jul 23, 2006 10:56 PM
red teg
Oct 9, 2005 03:33 PM
