stock b16 compression
whats the stock compression supposed to be at? i did a test and it came out to be 180ish across all 4 cylinders. my car burns about a half quart of oil per 250 miles or so... it blows smoke out pretty bad sometimes. i changed the valve seals and piston rings but it didnt help. the smoke? any ideas of what could be wrong?
valve guides might also be worn out and a bit oversize, but there's not too much besides the things you replaced that causes burning oil. Probably your break-in procedure wasn't good, or if you had to get rough with the seals to get them on they may have been damaged.
ewilliams1990
06-28-2014 03:44 AM
Brandon31386
07-23-2006 10:56 PM
Ri5e
06-20-2002 06:57 PM
