HELP! hah i got a little problem and idk if im right about it so please take a look.
Old Oct 25, 2007 | 09:54 AM
Bazza's Avatar
Default HELP! hah i got a little problem and idk if im right about it so please take a look.
i have a 94 del sol with a kinda built d16z6...
ok so heres the thing... i think i blew my piston rings...but not sure... heres what happens.
ok when i take off theres a huge cloud of blueish smoke and then whenever i downshift to like 2nd gear to slow down at stop signs/lights/w.e it just pours out blueish smoke till i stop and then when i take off again its just another cloud of smoke.
so im thinkin its the rings but idk if im right on this.... i just put new pistons and rings in (high compresson) like 3 months ago and i dint beat on it for about 600 miles for break in..so idk wtf happened... and no i dint put the pistons in myself i had my uncle whos a mechanic do it. so someone please help me with this!!!!
Modified by Bazza at 11:04 AM 10/25/2007
YO down below thanks for the info but i was told to take it easy... i beat the hell outta it after that so idk im runnin 13 sec quarter with only a little bit of work done to the motor... (all motor) cams/valves/pistons/rings/stage4clutch/lightweight flywheel/cold air intake/full 2.25 exhaust.
basic stuff
thanks for the info man...god damnit nother 400 on pistons WOOT!
Modified by Bazza at 11:42 AM 10/25/2007
Old Oct 25, 2007 | 10:24 AM
klungemonger's Avatar
Probably does it because you babied it and the rings didn't get to seat properly. Or did you also do something in the head like valve seals? Next time you rebuild it, which appears to be very soon, research the hard break-in and the theory behind why it's superior to feather-footing.
Old Oct 25, 2007 | 03:06 PM
Bazza's Avatar
yea idk well try that out thanks much but if anyone has any other comments on this i need to figure it out asap... cuz i gotta get this motor in top shape for my friend so i can get my b20b in :0
ianp3k
Apr 24, 2008 12:05 PM
XkjeldorX
May 6, 2007 10:11 AM
premo_si
Mar 5, 2006 08:31 AM
SweepeR 7
Nov 8, 2003 08:41 AM
genop
Sep 30, 2002 04:08 PM
