No heat. used to work jsut fine... very strange
Old Oct 24, 2007 | 09:19 PM
JDMB20TDA's Avatar
Default No heat. used to work jsut fine... very strange
As title states used to be running strong.
Now the fan still works in all speed and all that good stuff the way it should but, only blows ambient air temp.
If anyone has any ideas let me kno.
also what is the little switch going to heatercore do behind intake manifold area?
I recently rebuilt the tranny and might have bumped that thing with the rear mount when I replaced it.
Modified by JDMB20TDA at 11:21 AM 10/25/2007
Old Oct 24, 2007 | 11:55 PM
scobaru's Avatar
check ur coolant level's. I semi new to integra's but with my subaru the cable on the climate control has slipped off before becuase I've messed around in that area so the vent to switch over from cold to hot was stuck on cold.
if ur coolant is making it to ur heater core it should get warm.
Old Oct 25, 2007 | 05:16 AM
weavertime1's Avatar
Default Re: (scobaru)
Look and see if that valve you are talking about near the intake mainfold still has the small metal wire going to it. That valve is what allows coolant to get to and from the heater core. There could be an issue there, or like someone else stated, if the same type of wire has come unhooked from the climate control or the heater core under the dash somewhere the same type of thing could happen.
Old Oct 25, 2007 | 08:03 AM
JDMB20TDA's Avatar
Default Re: (weavertime1)
there wire is still there, but I dont think im getting any heat to my heater core.
I will investigate more today.
as I turn it to hot should the little valve open up?
also what can I do to get the climate control area of the dash board off?
I remember the heat control giving some resistance as I would adjust it in the past.
Old Oct 25, 2007 | 08:14 AM
JDMB20TDA's Avatar
Default Re: No heat. used to work jsut fine... very strange (JDMB20TDA)
Old Oct 25, 2007 | 12:36 PM
JDMB20TDA's Avatar
that little switch was the culprit I think its binding somewhere in the dash board.
I just flipped it towards firewall and now it blows hot.
Old Oct 25, 2007 | 02:44 PM
I kind of figured!!! Good luck finding the issue under the dashboard!!!
I Am The Ghost
Feb 10, 2010 07:25 AM
TaDLaD
Oct 1, 2009 11:31 AM
ColMustard
Jan 5, 2008 10:34 PM
Fatty_1775
Jul 18, 2005 07:23 PM
B16Civic93
Nov 15, 2004 03:56 PM
