i think these are codes 18 17 10 ef89dxcivic
Old Oct 24, 2007 | 07:29 PM
usfsfirefighter0's Avatar
Default i think these are codes 18 17 10 ef89dxcivic
Modified by usfsfirefighter0 at 9:49 PM 10/24/2007
Old Oct 24, 2007 | 07:33 PM
KrenzyRyan's Avatar
Default Re: i think these are codes 18 17 10 ef89dxcivic (usfsfirefighter0)
i see nothing
Old Oct 24, 2007 | 07:36 PM
crx-b16's Avatar
10 IAT - intake air temperature sensor
17 VSS - speed sensor
theres no code 18....
Old Oct 24, 2007 | 08:20 PM
Default Re: i think these are codes 18 17 10 ef89dxcivic (KrenzyRyan)
18 ?I will be posting link video of the sequence of flash to
help.
cel17 my speedo is not hook up is this why my vss cel is flashing? Also i don't get enough power because my car does let me get full rpm (it dances like i don't know how to use the clutch) in each gear unless im going down hill and after a long drive home from work i turn off my car and then it wont start unless push start it or just let it sit until i go work the next day then it starts right up, so short trips work up my leg muscles
Modified by usfsfirefighter0 at 9:31 PM 10/24/2007
Modified by usfsfirefighter0 at 9:33 PM 10/24/2007
Old Oct 24, 2007 | 08:29 PM
crx-b16's Avatar
Id think so I didnt put my vss all the way it and it came out little and I had a light for the vss so I just pushed it back in and it stopped..
Old Oct 24, 2007 | 08:37 PM
Default Re: i think these are codes 18 17 10 ef89dxcivic (crx-b16)
did you see light or how did you tell? did you lose peformance
Old Oct 25, 2007 | 01:25 PM
crx-b16's Avatar
light ya I had a check engine light so ya.. but I pushed it back in the tranny all the way and it turned off... oh course if you dont got your vss you will have a light and your speedometer wont work either so ya plug it back in...
Old Oct 31, 2007 | 05:42 PM
I was wondering if VSS effected the rpm as well(It feels like i have rev limiter).Im wait to put my speedo cable until tommrow. My clip was broken where it connects to back of speedo. I think its a cel code 1(O2 Sensor) I also found out this week. Thanks for every thing so far
usfsfirefighter0
10
Oct 30, 2007 11:06 PM
kingSfit
Apr 22, 2006 10:30 AM
HaUTSaauce
Mar 31, 2002 11:04 AM
Looose_R
Mar 27, 2002 04:49 PM
