Difference between regular teg and itr's rear lower subframe?
Old Oct 24, 2007 | 05:09 PM
01-0720's Avatar
Default Difference between regular teg and itr's rear lower subframe?
is there really a difference other then where the tie bar connects, iv been looking at some pics and cant really tell any differences, but my pics of a regular tegs subframe isnt to good
reason i ask if for asr subframe brace, call me a ricer, but i like the way they look, i know its not really needed, but it cant hurt if it will fit
Old Oct 24, 2007 | 05:23 PM
BlueIntegraBoy's Avatar
Default Re: Difference between regular teg and itr's rear lower subframe? (01-0720)
It should fit. The ITR subframe is thicker and has the mount for the tie bar.
Old Oct 24, 2007 | 05:42 PM
JjuuN R's Avatar
Default Re: Difference between regular teg and itr's rear lower subframe? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">It should fit. The ITR subframe is thicker and has the mount for the tie bar.</TD></TR></TABLE>
EEEEEENT, try again, ASR doesn't make a brace for the ITR, nor will any other chassis designs will line up with our holes...
/thread
Old Oct 24, 2007 | 05:47 PM
01-0720's Avatar
Default Re: Difference between regular teg and itr's rear lower subframe? (JjuuN R)
well that sucks, so there the same shape, but the holes are in different spots?
that sucks
i cant seem to get a good pic of a regular tegs rear subframe to compare
Old Oct 24, 2007 | 05:51 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 &raquo;</TD></TR><TR><TD CLASS="quote">call me a ricer</TD></TR></TABLE>
Ricer.
Old Oct 24, 2007 | 05:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">
/thread </TD></TR></TABLE>
On the back of my mind, I was thinking the bracket holes were different since the ITR's d-brackets bolt onto the subframe, while lower trim Integras use a mounting bracket.
Old Oct 24, 2007 | 06:14 PM
94rs-turbo's Avatar
actually i think it would work.. the lca bolts are the same length. and the sway bar would just bolt onto the brace but none the less its not needed on itrs
Old Oct 27, 2007 | 10:54 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (94rs-turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo &raquo;</TD></TR><TR><TD CLASS="quote">actually i think it would work.. the lca bolts are the same length. and the sway bar would just bolt onto the brace but none the less its not needed on itrs</TD></TR></TABLE>
think differently, it wont work
Old Dec 30, 2007 | 04:14 AM
fc3srx729's Avatar
Can the LTB bracket be bought separate, If yes, where...?
Old Dec 30, 2007 | 06:54 AM
Tiger_Si's Avatar
i had the same question a while back, and i found this....
Old Dec 30, 2007 | 11:11 AM
rhd94teg's Avatar
maybe he made his own holes
Old Dec 30, 2007 | 12:55 PM
01-0720's Avatar
Default Re: (rhd94teg)
thats luder94's black integra, its not a type r, it a reglar teg ls
Old Dec 30, 2007 | 01:38 PM
JjuuN R's Avatar
Default Re: Difference between regular teg and itr's rear lower subframe? (Tiger_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tiger_Si &raquo;</TD></TR><TR><TD CLASS="quote">i had the same question a while back, and i found this....
Since ITRs came with rear fork style suspension and all...
Old Dec 30, 2007 | 09:37 PM
SuckMyDOHC's Avatar
Since ITRs came with rear fork style suspension and all... </TD></TR></TABLE>
He must have the JDM Jasma ubber rare suspension. Whats the point of having a ASR brace AND a beaks tie bar??
SilverDC4
Sep 29, 2005 10:56 AM
IntegraBoy04
Aug 8, 2003 09:52 PM
JV
15
May 3, 2003 12:24 AM
Frito1
Aug 6, 2002 12:44 AM
BlueG3Teg
Feb 18, 2002 04:52 PM
