Beaks kit + Rear lower tie bar. Which ones fit?
Who?
Which rear lower tie bars are you using with the Beaks kit?
I'd like to go with something like this Benen piece:
But i'm not sure if i will have any fitment issues?
TIA
TIA
OG triple OG
Re: Beaks kit + Rear lower tie bar. Which ones fit? (JV)
the benen fits perfectly , i have the benen rear lower tie bar and the beaks kit with the itr sway bar , heres a pic
Re: Beaks kit + Rear lower tie bar. Which ones fit? (TURSpoonEK)
You need to take the .orig.jpg off at the end. Can't access the large pic. Here you go:
Edit: Not my suspension ^his
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">
Modified by g_man80 at 2:13 AM 5/3/2003
Who?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">the benen fits perfectly , i have the benen rear lower tie bar and the beaks kit with the itr sway bar</TD></TR></TABLE>
Thanks for the info...
But maybe i should have been alittle more specific in the application. It's for an "EG". The mounting point on the EG is alittle different...
hey JV..sup man..for the EG..i believe u want the longer bolts that Beaks offers..for this very issue. i know i didnt directly answer the "which works" but perhaps this could narrow it down for you a bit.
http://beaksproducts.com/upgrade.html
Modified by JaeOne3345 at 8:20 PM 5/2/2003
Who?
Re: Beaks kit + Rear lower tie bar. Which ones fit? (JaeOne3345)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 »</TD></TR><TR><TD CLASS="quote">hey JV..sup man..for the EG..i believe u want the longer bolts that Beaks offers..for this very issue. i know i didnt directly answer the "which works" but perhaps this could narrow it down for you a bit.
http://beaksproducts.com/upgrade.htm</TD></TR></TABLE>
Good stuff man, thanks...
I totally forgot that i could just Email Wil about it... on me
for a 92-95 the benen bar will work with beaks kit but you need to space the benen bar out about 1", beaksproducts also sells this "upgrade kit" that includes longer lca bolts and spacers to make this work for about 15$, the bolts are extremely hard to find.
i have the itr rear sway, beaks kit, benen bar, and beaks upgrade kit on my 94 coupe, and it fits perfect and made a huge difference in handling.
beaks has awesome customer service too.
btw, the skunk2 bar, and the neuspeed bar will not work at all, even with spacers, the spoon bar will work with no spacers but will cost you more than the benen with the spacers and i personally think the benen one is stronger and designed better.
Who?
Re: Beaks kit + Rear lower tie bar. Which ones fit? (euclid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euclid »</TD></TR><TR><TD CLASS="quote">for a 92-95 the benen bar will work with beaks kit but you need to space the benen bar out about 1", beaksproducts also sells this "upgrade kit" that includes longer lca bolts and spacers to make this work for about 15$, the bolts are extremely hard to find.
btw, the skunk2 bar, and the neuspeed bar will not work at all, even with spacers, the spoon bar will work with no spacers but will cost you more than the benen with the spacers and i personally think the benen one is stronger and designed better.</TD></TR></TABLE>
Perfect! Exactly what i wanted to know. Thank you very much...
Who?
Re: Beaks kit + Rear lower tie bar. Which ones fit? (xchosun1x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xchosun1x »</TD></TR><TR><TD CLASS="quote">i have EG with a beaks kit.....and the spoon tie bar fits with no problem...</TD></TR></TABLE>
Cool.
But IMO the Spoon bars are (Dare i say) cheesy...
Cool.
Re: Beaks kit + Rear lower tie bar. Which ones fit? (eg6si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6si »</TD></TR><TR><TD CLASS="quote">you can also use the jic-magic rear lower tie bar with the beaks/itr combination...$80+tax.</TD></TR></TABLE>
cool, that means the cusco and carbing will work too i think, they are the same design
the beaks kit reinforces the subframe so you can run the itr sway without damaging your civic. the itr subframes are reinforced from the factory and the civics are weak in comparison, the rear sway bar will rip out otherwise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">the benen fits perfectly , i have the benen rear lower tie bar and the beaks kit with the itr sway bar , heres a pic
NICE SETUP
NICE SETUP
Carpediem291
02-01-2004 04:13 PM
Bnjmn
10
07-05-2003 01:57 PM
