codes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiderhatch »</TD></TR><TR><TD CLASS="quote"> 41. Primary oxygen sensor heater
22. VTEC pressure valve
any ideas </TD></TR></TABLE>
need to replace you primary o2 sensor. should be the one near the header, before the cat.
VTEC pressure valve, replace the screen filter on the inside. but first inspect all wiring, make sure there isn't a break in the line.
after all the work is done, unplug the negative battery cable for about 5 minutes.
this should clear the codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spiderhatch »</TD></TR><TR><TD CLASS="quote">thanks</TD></TR></TABLE>
no problem!
no problem!
japspecjohn
13
Aug 9, 2004 07:17 PM
