New Master Cylinder.. Same Old Problem
Old Oct 24, 2007 | 11:21 AM
Jay Dirt's Avatar
Default New Master Cylinder.. Same Old Problem
Yes I've searched... and from searching it seemed as though my master cylinder had gone bad.
Symptom: bleed brakes, all four corners,.. hard as a rock
Start Car, pedal sinks to the floor, no pressure.
Turn car off, repump brakes, hard as a rock...
I replaced the master cylinder and have bled all 4 corners like 20 times...
what am i missing?
Old Oct 24, 2007 | 06:49 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: New Master Cylinder.. Same Old Problem (Jay Dirt)
seems like you got a leak somewhere??? a bad one maybe?
Old Oct 24, 2007 | 06:55 PM
sony224422's Avatar
Default Re: New Master Cylinder.. Same Old Problem (I got the CD5 Jeebies!)
your slave cylinder could be going out.
Old Oct 25, 2007 | 09:37 AM
Jay Dirt's Avatar
theres no fluid leaking anywhere...
Old Oct 25, 2007 | 10:01 AM
sony224422's Avatar
slave cylinder loosing pressure or something
Old Oct 25, 2007 | 11:09 AM
Honda-Master's Avatar
Default Re: New Master Cylinder.. Same Old Problem (sony224422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 &raquo;</TD></TR><TR><TD CLASS="quote">slave cylinder loosing pressure or something</TD></TR></TABLE>
Stop it with the slave cylinder will you ???
Did you bench bleed the master before you installed it ??
If so,, you might have a bad master cylinder.. did you use a Honda part ??
if no leaks , you bench bled it, bled system correctly,, you might want to exchange the master cylinder ,,
Old Oct 25, 2007 | 11:20 AM
Bruce Banner's Avatar
Default Re: New Master Cylinder.. Same Old Problem (Honda-Master)
yeh apparently sometimes people get bad master cylinders.
I would try another one.
Old Oct 25, 2007 | 11:36 AM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Master &raquo;</TD></TR><TR><TD CLASS="quote">
if no leaks , you bench bled it, bled system correctly,, you might want to exchange the master cylinder ,, </TD></TR></TABLE>
whys that? it could be bad could it not? im honeslty wondering.
Old Oct 25, 2007 | 11:45 AM
whys that? it could be bad could it not? im honeslty wondering.</TD></TR></TABLE>
sony my friend slave cylinder has nothing to do with brake system,,
it is to do with a hydraulic clutch system
Old Oct 25, 2007 | 12:26 PM
accord99power's Avatar
honda master is right.
Old Oct 25, 2007 | 12:30 PM
Jay Dirt's Avatar
Default Re: New Master Cylinder.. Same Old Problem (accord99power)
Yes I did bench bleed it, no it's not an OEM honda, it's an aftermarket from Napa.. I will exchange it tomorrow
Old Oct 25, 2007 | 01:48 PM
sony224422's Avatar
ahh i dk why i was thinking that. brain fart
Old Oct 25, 2007 | 03:28 PM
noobking's Avatar
You'll probably have to re bleed your entire system again won't you? The air probably traveled into your lines.
Old Oct 25, 2007 | 03:33 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: New Master Cylinder.. Same Old Problem (noobking)
try bleeding it on the car before removing it..
Old Oct 26, 2007 | 05:53 AM
Jay Dirt's Avatar
i had all 4 calipers off the car, the car sat for a year and the brakes were rusted so i took everything off cleaned it up, replaced the rear rotors and pads and cleaned up the fronts so it's no big deal to rebleed the whole system
Old Oct 26, 2007 | 10:59 AM
just a tip, check the caliper slides while you have the calipers off if you havent already repack them if they have never been done. not saying this is the prob though.
Old Oct 26, 2007 | 12:33 PM
keps39's Avatar
You just change your cylender again , i think it may fix your problem !
just try that !
Old Oct 26, 2007 | 05:27 PM
FUSIBLE2DO's Avatar
just a recommendation ... get some nails disconnect the lines from master cyl the nails must fit inside the brake lines... cut nails about 1/4 inch from head .... insert one nail on each line connect lines back to cylinder and tighten lines , depress pedal should be rock hard , if it is, your cylinder is good if it still goes down cylinder no good ... hope it helps
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
djkurious
May 19, 2009 04:22 PM
iwanttogofast
Jul 24, 2007 01:58 PM
stickman12
Sep 14, 2005 02:09 PM
