Timing belt tensioner???
How often or common are these things going bad? I have noise from my motor and someone suggested the timing belt tensioner.1 day it will sound like a slight bearing tapping or rapping and the next like a heat sheild sound from the side where the timing belt is.Any Idea's
I'm just going by the noise of it.It sounds like a faint bearing noise but it has changed from day to day.1 day like a bearing constant and the next like a metal tin rapping or vibrating on and off.It has just started this noise the last 2 weeks.The car doesnt burn any oil and has all kinds of power.
Aaaa..... You should not drive a car that is making wierd noises (unless you know what they are)
Take it to a mechanic if you can't figure it out.
How many miles?
Last T-belt change?
Tensioner done with it?
How many miles?
Last T-belt change?
ekx4
Aug 28, 2006 12:18 AM
