ITR final gear vs LS LSR in turbo applicatoin
Old Oct 24, 2007 | 08:29 AM
Liu Kang's Avatar
Default ITR final gear vs LS LSR in turbo applicatoin
Hey wondering what is going to be better, if I have a turbo 18B egine, what is the best option for the drive? I had already gotten a LSD for the LS tranny but was thinking about the JDM LSD with a final drive. With the turbo, you will be going though the gears pretty fast so won't it be better to stick with the LS gears? What about the fifth gear? Is shorter faster for top speed? I mean I will have a built engine, bottem end and everything, probably boosting about 1bar, so what will be faster on the top end? What is better?
Old Oct 24, 2007 | 08:35 AM
AWD Terror's Avatar
Default Re: ITR final gear vs LS LSR in turbo applicatoin (Liu Kang)
WHP? Goal?
Bar means jack shi<U></U>t in terms of HP
Old Oct 24, 2007 | 08:43 AM
Liu Kang's Avatar
Default Re: ITR final gear vs LS LSR in turbo applicatoin (AWD Terror)
no, I think your wrong, but giving what you plan on boosting to, it should give you a great idea of how hard you will be pushing it, I guess a ballpark figure in terms of horsepower would be 280?
Old Oct 24, 2007 | 08:45 AM
bjones's Avatar
in boosted cars, gsr final drive is good
Old Oct 24, 2007 | 08:51 AM
hatchling37's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liu Kang &raquo;</TD></TR><TR><TD CLASS="quote">no, I think your wrong</TD></TR></TABLE>You are wrong. You need to go read up in the Forced 101. Also, you won't be able to use the ITR LSD with the LS mainshaft. Boosting all the way through longer gears doesn't mean better acceleration.
Old Oct 24, 2007 | 09:08 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liu Kang &raquo;</TD></TR><TR><TD CLASS="quote">no, I think your wrong, but giving what you plan on boosting to, it should give you a great idea of how hard you will be pushing it, I guess a ballpark figure in terms of horsepower would be 280?</TD></TR></TABLE>
You are stupid. PSI (or bar) means jack **** in terms of HP.
Sounds like you need to read up on some information before you start on a porject like this.
Old Oct 24, 2007 | 09:30 AM
Liu Kang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like you need to read up on some information before you start on a porject like this.</TD></TR></TABLE>
whatever... I know lots of people with huge hps that can't even get in the 12s so you can say whatever you want, hp doesn't mean ****!!!
Old Oct 24, 2007 | 09:31 AM
AWD Terror's Avatar
PSI will not tell you HP. HP will not tell you quarter mile times. You power band should give you a good indication of quarter mile.
You should really shut up and start reading, you are making yourself look like an ***
Old Oct 24, 2007 | 09:32 AM
Liu Kang's Avatar
Default Re: ITR final gear vs LS LSR in turbo applicatoin (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">You are wrong. You need to go read up in the Forced 101. Also, you won't be able to use the ITR LSD with the LS mainshaft. Boosting all the way through longer gears doesn't mean better acceleration.</TD></TR></TABLE>
It does if it means you only have to go though 4 gears instead of 5, cause it's less time wasted shifting...
Old Oct 24, 2007 | 09:34 AM
thewrai6th's Avatar
AWD Terror is correct. Read up on the FAQ's and you will understand why.
Liu Kang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">PSI will not tell you HP. HP will not tell you quarter mile times. You power band should give you a good indication of quarter mile.
You should really shut up and start reading, you are making yourself look like an ***</TD></TR></TABLE>
ok, so school me, tell me how it makes any difference how many horses I plan on making? how on earth does that number going to tell you what tranny setup I should go with?
Old Oct 24, 2007 | 09:40 AM
AWD Terror's Avatar
ok, so school me, tell me how it makes any difference how many horses I plan on making? how on earth does that number going to tell you what tranny setup I should go with? </TD></TR></TABLE>
What you should do is find a dyno of a car with a similar set up. See where the car makes the most power, and get a tranny that will keep you in your power band the longest.
Edit: I'm not on here to fight with people, just don't tell me I'm wrong unless you are 100% sure.
Old Oct 24, 2007 | 09:44 AM
thewrai6th's Avatar
AWD was trying to help, by asking what your HP and goals are. Are you shooting for a 1/4 mile time? or are you trying to go 160 on the freeway?
Your power levels can tell you where you want to be in the 1/4 mile. The amount of boost you run tells you nothing without the rest of the setup.
Old Oct 24, 2007 | 09:47 AM
Liu Kang's Avatar
Edit: I'm not on here to fight with people, just don't tell me I'm wrong unless you are 100% sure.</TD></TR></TABLE>
yea, thats about right, I knew that but was hoping to find someone with about the same setup and see what they advise, I never actually said you were wrong, I just said that "I think..." as for searches, man, I can't seem to phrase the right words or something, I can't even get good returns on my searches. I think I'll just take the easy way out and run the LSD in the LS turbo and see how that goes. Everything else seems to be much more money and complicated, so thanks to everyone for their input, I do appreciate it.
Old Oct 24, 2007 | 09:53 AM
thewrai6th's Avatar
Search "post bodies" and/or "Archived Content"
Old Oct 24, 2007 | 09:56 AM
AWD Terror's Avatar
yea, thats about right, I knew that but was hoping to find someone with about the same setup and see what they advise, I never actually said you were wrong, I just said that "I think..." as for searches, man, I can't seem to phrase the right words or something, I can't even get good returns on my searches. I think I'll just take the easy way out and run the LSD in the LS turbo and see how that goes. Everything else seems to be much more money and complicated, so thanks to everyone for their input, I do appreciate it.</TD></TR></TABLE>
Give us ALL the information about your build. We could tell you what numbers to expect with a good tune.
List EVERYTHING performance:
Turbo (brand & size)
Exahust (manifold & cat back size and brand)
Clutch (if your going other than stock)
Injectors
What your tuning with
You get the point
Old Oct 24, 2007 | 10:05 AM
dizzzane's Avatar
Just curious, with all other variables controlled, ie fuel, spark, timing, etc... isn't boost a decent indicator of power... more boost=more air=more power? Or is that more based on the tune?
Old Oct 24, 2007 | 10:07 AM
AWD Terror's Avatar
Default Re: ITR final gear vs LS LSR in turbo applicatoin (dizzzane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, with all other variables controlled, ie fuel, spark, timing, etc... isn't boost a decent indicator of power... more boost=more air=more power? Or is that more based on the tune?</TD></TR></TABLE>
No. You need to look at the compressor maps.
Some turbos spool up fast and lose efficency in the top end.
Others take too long to spool up and will never reach full boost on our little 1.8
Old Oct 24, 2007 | 10:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Just to chip in final drive ratio. A higher final drive ratio will REDUCE your top speed. It will put you in the powerband at lower speeds, compared to the stock final drive.
For example, stock GS-R's redline in 1st around 30 mph. With a higher final drive, it might redline at 25 or even 20 mph.
I've seen people running the ATS 4.9 final drive, and they end up in 5th gear by the time they reach the 1/4 mile, but in each gear they got to redline faster than if it were the stock final drive.
So a GS-R with a theoretical gearing-limited top speed of 150-155 (8200 rpm in 5th gear) might only make it to 120 or so before the fuel cuts out in 5th.
Old Oct 24, 2007 | 07:38 PM
Liu Kang's Avatar
Injectors
You get the point</TD></TR></TABLE>
Lets see...
b18b block with a Nu-Formz block guard
ARP headbolts
Clevite race bearings
Crower sportmans rods
JE pistions 9:1 compression
The cylinders have been hones 1/4 of a millimeter to compensate for the race pistons which are 81 1/4 MM
Vtec high volume oil pump
crower 31.5mm intake valves
crower 28.5mm exhuast valves
crower dual valve springs for the springs and retainers
crower retainers
inline four bronze valve guides
new oem valve seals
new cam followers
port and polished head
skunk 2 70 mm throttle body
blox intake manifold
type R throttle cable
RC 450 injectors
walbro 255 fuel pump
AEM fuel rail and regulator
Skunk2 catback exhaust
402T crower cams with adjustible camgears
Golden Eagle vacuum manifold
Greddy turbo kit
fmic with pipes
blitz bov
to control everything
Greddy blue emange
Greddy e01 boost controller
greddy gauges
blox LSD
not sure on the clutch yet, looking for something good at a great price (got something good, send me a pm)
probably lots more but forgot to memtion
Old Oct 25, 2007 | 08:42 AM
thewrai6th's Avatar
Greddy 18G Kit @ 15psi? Shorter gears are better, you will probably not hit 5th in the 1/4 mile. You can always change the size of the tires to adjust the final drive.
Old Oct 25, 2007 | 06:52 PM
Liu Kang's Avatar
Default Re: ITR final gear vs LS LSR in turbo applicatoin (thewrai6th)
Hey thewrai6th, yes they are Greddy 18G, will that hold 15psi up to redline?
Old Oct 26, 2007 | 08:50 AM
thewrai6th's Avatar
My 19t can hold 10 to redline, and it's tiny. The 18G should hold 15 no problem.
Keep in mind there are better kits for the money.
Old Oct 26, 2007 | 09:01 AM
Liu Kang's Avatar
yea, I know there are better kits, I got it for my friend who wanted that specific kit and then backed out after I got it so, now I got it and just doing what I can with what I got...
Old Oct 26, 2007 | 09:12 AM
thewrai6th's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liu Kang &raquo;</TD></TR><TR><TD CLASS="quote">now I got it and just doing what I can with what I got...</TD></TR></TABLE>
That's why I run a 19t.
turbotime
May 2, 2006 10:15 PM
coconutsoldier
Jun 24, 2005 04:48 PM
zbower7
Feb 23, 2004 07:32 PM
p1ccoloz
Mar 15, 2003 08:21 PM
WykidEH
Oct 9, 2001 09:00 AM
