90 Integra (LSVTEC Converted to OBD1) Boggs after vtec hits
Okay so last night me and my friend decided to convert his OBD0 Integra LSVTEC into OBD1 using the Pigtail conversion..We did exactly what the manual says, hooked it all up and started the car, it started fine and there was no check engine light ,so we took it out for a test run.... runs good from 2-5.5K, but when vtec hits after 5.5k or so, the car boggs and rpm goes really slow... almost like a CX motor..WTF??? I was kind of leaning towards the distributor because it was just a piece together distributor... any thoughts on this??? Need it running because we are heading to BOTI in FAMOSO, CA.... lmk
btw this is what the engines got.
95 GSR head stock
Stock OBD0 LS injectors
Stock GSR manifold (we took out the Secondary Butterfly)
stock GSR TB
Stock cams
stock header
LS block
p30's .25 Over
LS rods
ARP rod bolts
Vtec oil/water pump
Engine management:
OBD1 P28 Chipped ECU
95 GSR head stock
stock GSR TB
Stock cams
stock header
LS block
p30's .25 Over
LS rods
ARP rod bolts
Vtec oil/water pump
Engine management:
ok we changed the distributor to a new one and it does not bogg or back fires anymore, but theres another problem, it has no power at all from 2000 rpm all the way to 8000 rpm.... feels slower than a weak *** single cam CX motor... rpm climbs very very slow.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid »</TD></TR><TR><TD CLASS="quote">Sounds like the cam timing is off. Put the cams and the crank all at TDC. (marks lined up)
I bet the timing is off on one of your cam gears..
we went to a friends shop and double check the timming and the Intake cam gear was off from the TDC mark on the head, it was retard, so i re-did the timming and now it pulls harder than a muthaF*****........thanks for the help guys....
BOTI here we come!!!!!! lol
</TD></TR></TABLE>we went to a friends shop and double check the timming and the Intake cam gear was off from the TDC mark on the head, it was retard, so i re-did the timming and now it pulls harder than a muthaF*****........thanks for the help guys....
