SH knowledge needed: '97-'99, '00, '01 Difference?
ok, so i know there are plenty of difference from the SH and the base model 5th gen's but what i really need to know is, how interchangable are the SH blocks? My interchange program is showing that they are all different.... is it just an obd2a computer vs. an obd2b computer? or are there actual differences in the block (between the years, NOT between base and SH!)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 »</TD></TR><TR><TD CLASS="quote">ok, so i know there are plenty of difference from the SH and the base model 5th gen's but what i really need to know is, how interchangable are the SH blocks? My interchange program is showing that they are all different.... is it just an obd2a computer vs. an obd2b computer? or are there actual differences in the block (between the years, NOT between base and SH!)...
Search the FAQ on top and youll get all your answers
already did... what words are you using? is shows me the difference between the base model and SH model, i already know that stuff... i need to know if a 97-99 or a 01 SH will work in a 2000 SH car, and if so what i need.... i just need a replacement motor but was hoping these would interchange but like i said i looked through Holander interchange program which is used nation wide, and it was not help, if you could link me to where your seeing that would be great... thanks
:Bump: FYI: checked search archived and current for 'sh differences' and for 'sh prelude' body and topic, and still no information useful, so the real question is...instead of not posting at all you decided to be a smart *** about it, but did YOU search?
Anyone with help...ty in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms »</TD></TR><TR><TD CLASS="quote">nothing is different the 97 is the same as the 01 sh. </TD></TR></TABLE>
You're fogetting about the Crankshaft differences between year 1997 Preludes and 1998-2001.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi »</TD></TR><TR><TD CLASS="quote">50mm mains to 55mm mains between 97 and 98-01. As far as the block fitting into different years there is not problem.</TD></TR></TABLE>
thanks revi
was waiting on your response... remembered seeing the signature awhile back... wont a type S go without problems to a SH and have functional ATTS?
babigurllao
May 18, 2008 01:14 PM
Bigjussin
Dec 12, 2003 10:58 AM
