CATALYTIC CONVERTER 02 SENSOR
Old Oct 23, 2007 | 03:47 PM
RVARGAS64's Avatar
Default CATALYTIC CONVERTER 02 SENSOR
NEED SOME HELP,,
REPLACING CAT, NEED TO DISCONNECT 02 SENSOR WIRES...
RUNS THRU GROMMET UP INTO , I THINK CENTER CONSOLE??NOT SURE IF I CAN DISCONNECT THERE...LIKE TO MAKE SURE BEFORE I START TEARING DOWN
CENTER CONSOLE AREA!!
DON'T WANT TO TAKE IT OFF, WITH CAT IN PLACE ..
HAD HELL TAKING OFF MANIFOLD 02 SENSOR!!
OLD GUY NEEDS SOME HELP !
THANKS!
98 CIVIC EX B16Y8
Old Oct 23, 2007 | 03:51 PM
Padawan's Avatar
Darth ModerVader
Default Re: CATALYTIC CONVERTER 02 SENSOR (RVARGAS64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RVARGAS64 &raquo;</TD></TR><TR><TD CLASS="quote">NOT SURE IF I CAN DISCONNECT THERE...</TD></TR></TABLE>
You can. Just pull the grommet out, and you'll see the plug.
And please, no more caps lock.
Old Oct 23, 2007 | 03:52 PM
JKov240's Avatar
If I'm thinking of what you're thinking of, there should be a little rubber grommet on the bottom of the car...give that a tug and pull it out.
Keep pulling the wires out and the connector and the plug that the connector plugs into should come out through the bottom of the car.
Old Oct 23, 2007 | 03:57 PM
RVARGAS64's Avatar
Default Re: CATALYTIC CONVERTER 02 SENSOR (JKov240)
sorry,pad.. didnt mean to yell!!
hows this!!
caps look better to these eyes
thank you!
for your help!!
Padawan's Avatar
Darth ModerVader
Old Oct 23, 2007 | 04:02 PM
JKov240's Avatar
No problem
EDIT: (1,000 posts...woohoo! )
Old Nov 14, 2007 | 08:44 AM
ixoiiiiviviiivi's Avatar
Default Re: CATALYTIC CONVERTER 02 SENSOR (Padawan)
I have a 99 Dx with a 99 Si Swap. As you know the dx has both o2 sensors going into the main engine harness, but the si only has one plug for the header o2 sensor. is there a plug in the dx dash engine harness to plug in the second o2 sensor?
Old Nov 14, 2007 | 08:53 AM
Padawan's Avatar
Darth ModerVader
Default Re: CATALYTIC CONVERTER 02 SENSOR (ixoiiiiviviiivi)
To my knowledge, you will have to run your own wiring to the secondary O2, either from the ECU or from the engine harness.
teggsr925
Apr 5, 2010 04:37 PM
DeDonDeRosa
Sep 23, 2006 02:45 PM
escape2me
Nov 24, 2005 06:30 PM
danman3323
Oct 29, 2004 10:18 PM
