Oil temperature needle issue
Old Oct 23, 2007 | 01:44 PM
spnej1's Avatar
Default Oil temperature needle issue
Ok, so I installed a sandwich plate adapter inbetween my oil filter 2 days ago.
I installed the electrical sending peice for the gauge. Then I crimped the sending unit wire to a butt connector and secured it on the sender.
Then I ran the wire through the firewall, used a wirenut to connect the wire from the gauge to the sending wire, and hooked up the positive and negative wires to the gauge.
It is a Faze EL oil temp gauge.
Once I started the car, the needle automatically rose to 130F with the engine COLD.
Then, it just kept rising and rising until it hit the max at 280F. Literally, in 4-5 minutes. I know the oil is NOT that temperature. The head is barely hot.
What is weird is the constant raising of the needle when the car is idling.
I know the needle is off, and I cannot understand the problem here.
Old Oct 26, 2007 | 10:12 AM
spnej1's Avatar
Default Re: Oil temperature needle issue (spnej1)
Bump
rdssk8rcs1
Jan 26, 2006 07:12 PM
Ibuprofen
Feb 5, 2005 05:10 AM
ss20gsr
Jan 30, 2004 08:33 PM
Ludester
Nov 16, 2002 01:13 PM
