ek problem
Old Oct 23, 2007 | 09:17 AM
MIKE_HWD's Avatar
Default ek problem
every time i roll down my windows (power windows) they jump off track any suggestions?
Old Oct 23, 2007 | 09:26 AM
Probot's Avatar
Default Re: ek problem (MIKE_HWD)
either take the door apart yourself and put the windows back on track or take it to someone who can do it
Old Oct 23, 2007 | 09:41 AM
B00STNH22EK's Avatar
spray some silicon in the tracks to see if that helps...i had the same problem with my doors...
Old Oct 23, 2007 | 09:58 AM
MIKE_HWD's Avatar
Default Re: ek problem (B00STNH22EK)
i put it back on track and i tried the silicone but it gets annoying having to take the door panel off every time i put my window down any other suggestions someone told me it could be the regulators
Old Oct 23, 2007 | 10:54 AM
yea i know..i went through the same thing you're going through...it's not the regulators...it's something with the tracks...mainly that front track by the mirror...silicone helped my problem for the most part...i ended up getting 99-00 civic doors because i shaved my other doors and changed to the jdm style and haven't had a problem with the new doors...
Modified by B00STNH22EK at 5:19 AM 10/24/2007
Old Oct 23, 2007 | 03:26 PM
NOFX's Avatar
H-T White Ops
problem with windows popping off the track is that it might start with one thing being out of line, but then more things get out of line too. So if you replace the tracks, for example, you think that fixed it only to find out that the regulator has been bent because of forcing the window down crooked. So you really don't know what is broken and needs to be replaced.
Old Oct 23, 2007 | 04:46 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (NOFX)
there is a bulletin at honda for this, they replace window motor(regulator) and the run channel.
when i do them at work i sometime just take the window out and take off the window run channel and take it and clean it with soap and water, sometimes it works sometimes i still have to put the window motor in.
Old Oct 23, 2007 | 07:08 PM
JDMB0YS's Avatar
Default Re: (B16B_coupe)
i had the same problem silicone the tracks if that doesnt work then replace them there prolly bent up!!
Old Oct 23, 2007 | 08:07 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (JDMB0YS)
Easiest solution is to take the panels off and look.
EJ8chu
Jan 11, 2007 09:15 AM
bleedblue94
16
Nov 25, 2006 09:04 PM
Silverdot
Jun 24, 2006 04:42 PM
lp3kr
15
Apr 1, 2002 11:16 PM
96 Accord Ex V6
Jan 11, 2002 02:19 PM
