Help me get my speedometer working. Have searched.
Old Oct 23, 2007 | 04:34 AM
bcrosby51's Avatar
Default Help me get my speedometer working. Have searched. xxREVISEDxx
My speedo has not worked since I bought my car earlier this summer. 98 GSR. I just got a new VSS, my old one was missing the square pin. So I got that in and still nothing. I checked the fuses, all good, checked the three wires on the VSS harness, got Ground, 12v and 9v on the three. I have cleaned the connections on the plug and everything. What else could it be? I reset the check engine code, which was the VSS code. I just want a working speedometer, please help.
Modified by bcrosby51 at 12:08 PM 11/3/2007
Old Oct 23, 2007 | 06:08 AM
weavertime1's Avatar
Default Re: Help me get my speedometer working. Have searched. (bcrosby51)
Have you actually replaced the gauge cluster, or at least tried a working one to make sure it wasn't just your cluster? I had this sort of problem before and once it was the cluster, and once it was actually an issue inside of the transmission. Hopefully it is the former and not the latter.
Old Oct 23, 2007 | 06:59 AM
bcrosby51's Avatar
Default Re: Help me get my speedometer working. Have searched. (weavertime1)
I have not tried the cluster. That is the last thing I want to try. Is there a way to test that out at all without buying a new cluster? The guy I bought it from said it worked but he lost the square pin in the VSS, so I got a new one and it still doesn't work.
Old Oct 23, 2007 | 07:32 AM
Seems fishy...maybe he was telling you that so that you would think it was just the square pin, and not something in the tranny. I do not know of a way to test that other than borrowing someone's cluster and trying it out.
Old Oct 23, 2007 | 07:38 AM
bcrosby51's Avatar
I could see him doing that. He seemed fishy himself. I can see the gear in the tranny that spins the VSS gear, but I guess I would have to put the car in the air and spin the tires to see if that gear is actually moving. I don't know if this would work, but I put my drill on the plug side of the VSS and turn the car on and spun that shaft and my speedometer didn't move then either.
Old Oct 23, 2007 | 07:44 AM
Boy that sounds like the cluster...If you lived closer I'd let you try one of mine first. If you end up needing one...I have a speedometer I would sell for 25 shipped.
Old Oct 23, 2007 | 07:56 AM
bcrosby51's Avatar
Is that for the whole cluster or just the speedometer part?
Old Oct 23, 2007 | 08:46 AM
Thats just for the speedo part...the whole cluster would be $50 shipped for a gsr. I just happened to also have a parts cluster out of a gsr as well that had the plastic broke for the surround. Thanks!!!
Old Oct 23, 2007 | 09:21 AM
bcrosby51's Avatar
Do you know for sure that the speedo worked in that cluster?
Old Oct 23, 2007 | 11:07 AM
Yes, but I could reinstall it in another car just to make sure...and let you know back? Thanks!!!
Old Oct 23, 2007 | 11:48 AM
bcrosby51's Avatar
Yeah let me know, if it works I will take it. I guess I am going to have to do the process of elimination on this one.
Old Oct 30, 2007 | 07:57 AM
bcrosby51's Avatar
Did you get a chance to test that speedo out?
Old Oct 30, 2007 | 08:15 AM
Yes it works fine!!! Do you want it still. If so I will send it after I recieve a paypal payment of $25. I will ship it USPS priority. Thanks!!!
Old Oct 30, 2007 | 09:55 AM
bcrosby51's Avatar
Yep, I'll take it. What is your paypay instructions?
Old Oct 30, 2007 | 01:45 PM
integra_freak96's Avatar
make sure your distributor isnt of it has to be set in the middle or just loosen the bolts and wiggle it back and forth then put back in the middle and tighten up.....i have the same problem when i advance my timing threw the distributor.
Old Oct 31, 2007 | 04:53 AM
bcrosby51's Avatar
Default Re: Help me get my speedometer working. Have searched. (integra_freak96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_freak96 &raquo;</TD></TR><TR><TD CLASS="quote">make sure your distributor isnt of it has to be set in the middle or just loosen the bolts and wiggle it back and forth then put back in the middle and tighten up.....i have the same problem when i advance my timing threw the distributor.</TD></TR></TABLE>
What does this have to do with the speedometer not working?
Weever, what are your paypal instructions?
Old Oct 31, 2007 | 06:37 AM
PM'ed
Old Oct 31, 2007 | 06:44 AM
dizzzane's Avatar
I was going to suggest trying a new cluster. If you replaced the square pin in the VSS, it has to be the cluster or the tranny. Let us know if the new cluster fixes your problem.
Old Nov 3, 2007 | 11:10 AM
bcrosby51's Avatar
Default Re: Help me get my speedometer working. Have searched. (dizzzane)
Okay, so I got the new cluster in....still nothing. So, I tried taking the sqaure pin out of the new VSS and putting in my old VSS to make sure it wasn't something in the VSS....still nothing. I am still getting a check in light code 17, which is the VSS? Any ideas?
Old Nov 3, 2007 | 01:13 PM
MoreBoost!'s Avatar
i had the same problem when i pulled my tranny out. all it was is the pins on the harness was not well seated on the vss. all i did is used a small screw driver n bent the pins on the harness so it would have a better fit.
Old Nov 7, 2007 | 04:54 AM
bcrosby51's Avatar
Default Re: Help me get my speedometer working. Have searched. (MoreBoost!)
I finally got my speedo working. Ended up being the plug on the VSS. The clips on the wires had been opened up so they weren't making contact with the connectors on the VSS. YEAH!!!
chicklet
Sep 11, 2016 08:11 AM
_EF9
Apr 21, 2013 09:59 AM
B16Civic93
Feb 21, 2012 02:15 AM
ram0869
Sep 5, 2009 09:11 PM
ma_rio44
11
Jul 15, 2007 09:24 AM
