Big problems with VTEC H22A2
Hello,
I have big problems with my VTEC, smetimes it kicks in, but usually dont.
I think i tryied everything... VTEC solenoid changed and cleaned, EGR changed and cleaned, oil changed, ECU doesn't shows any errors. So where could be problem?? please help
Car Prelude 4Gen H22A2 engine (EDM, 185 HP)
Speedo doesn't works perfectly, but i thing it shouldn't affect VTEC, because when im going on 20km/h it shows 0km/h, on 40km/h it shows 20km/h, on 60km/h shows 40 and ect..... i think it can affect'VTEC only on first gear, but on second gear when speed more than 50-60km/h VTEC doesn't kicks in too
P.S. How to check oil presure? I think if oil presure would be low, the ECU should show an error....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImmOr7aL »</TD></TR><TR><TD CLASS="quote">
P.S. How to check oil presure? I think if oil presure would be low, the ECU should show an error....</TD></TR></TABLE>
to a degree your right. But you can also not have enough oil pressure for vtec and still have no error lights. Check your oil level and check for oil leaks.
Thank you, but i forgot to say, that motor reving past 6400 rpms, til 7000 or even 8000 rmp, but sometimes there is Solenoids click on 5000rpm, and i can feel and hear VTEC, and sometimes there is nothing, engine just reving 6400rpm, but there is no VTEC
Edit: Oil pan is really dented, will try to change it.
Thank you for advices
Modified by ImmOr7aL at 2:17 PM 10/25/2007
1JDMDOMINICAN
Mar 20, 2007 02:03 PM
streetracerjoey210
11
Sep 23, 2006 03:53 PM
