adjusting FPR
Old Oct 22, 2007 | 10:58 PM
slow_db7's Avatar
Default adjusting FPR
how exactly do you adjust your fuel pressure? could you bring up the pressure even though you have stock injectors? also, how would you know if your running too rich or too lean or just right? thanks
Old Oct 23, 2007 | 07:46 AM
all-mtr-teg's Avatar
Default Re: adjusting FPR (slow_db7)
wideband
Old Oct 23, 2007 | 09:36 AM
Relic1's Avatar
adjusting the FPR is pointless unless you're tuning the car, or at least have a wideband to tell you what's going on.
Old Oct 23, 2007 | 02:57 PM
slow_db7's Avatar
hahaha.. well i guess imma bump this up cuz no one answered my question yet.. i know u need a hex key and maybe a 10 or 12mm wrench but which way is increasing the PSI and decreasing it and the actual procedures to adjust it
Old Oct 23, 2007 | 03:15 PM
Padawan's Avatar
Darth ModerVader
Default Re: (slow_db7)
The adjustment method depends upon what regulator you're using. Some use a wrench and a screwdriver, others may use an allen key, etc...
Old Oct 23, 2007 | 03:47 PM
horchata's Avatar
i'd just leave it up to your tuner...unless of course you do have the knowledge to do it yourself.
Old Oct 23, 2007 | 06:57 PM
do you even got a fuel gauge that tells you fuel pressure, if so, turn it one way and check if pressure increases or decreases, damn, how old are you, like 10? This is common sense stuff, if you can't figure that out, find someone who's mechanically inclined and have them show you or at least be there with you while you're wrenching on your car.
Old Oct 23, 2007 | 11:29 PM
slow_db7's Avatar
Default Re: (all-mtr-teg)
cheese i just wanned to know the right way.. and plus i been reading about u having to take out the hose on the FPR or watever.. i didnt know some people in the mainland can be such a holes.. atleast people in hawaii help out other people to make them better and not bring them down... now i know not to ask for help from all-mtr-teg cuz he goin get mad.. sorry eh brah
AND i wanned to know how you could tell if its too rich or lean? all-mtr-teg u dont have to answer that question
Old Oct 24, 2007 | 06:34 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_db7and plus i been reading about u having to take out the hose on the FPR or watever..[/QUOTE &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, you must remove the vacuum hose before adjusting it.
[QUOTE=slow_db7]AND i wanned to know how you could tell if its too rich or lean? all-mtr-teg u dont have to answer that question</TD></TR></TABLE>
You need a wide-band O2 sensor and gauge to do it properly.
Old Oct 24, 2007 | 08:06 AM
TheSauceSpot's Avatar
what is a decent FPR to use?
is a b&m good enough? i see everyone spending 100-200$ on AEM and Aeromotive..???
Old Oct 24, 2007 | 08:41 AM
Padawan's Avatar
Darth ModerVader
Default Re: (HOTSAUCE01)
In most cases yes, the B&M is perfectly sufficient.
Old Oct 24, 2007 | 10:39 AM
yeah, its a stock b18c w/ bolt ons.... thanks for the advice!
Old Oct 24, 2007 | 11:07 AM
if its stock w/ just bolt ons, no need for a FPR or bigger injectors for that matter
Old Oct 26, 2007 | 06:58 AM
D16Z6TURBO's Avatar
on an aem fpr loosen the nut (10mm) and turn hex key to achieve desired pressure DO NOT ADJUST PAST 43.5 psi
Old Oct 26, 2007 | 07:21 AM
Padawan's Avatar
Darth ModerVader
Default Re: (D16Z6TURBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6TURBO &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT ADJUST PAST 43.5 psi </TD></TR></TABLE>
Why is that?
Old Oct 26, 2007 | 07:25 AM
D16Z6TURBO's Avatar
your ECU is calculating your pulse width based off a known number of fuel ie 43.5 psi excess fuel pressure will only result in a slight gain in fuel and can eventually overwork your injectors ever notice that your tuner sets your FP before tuning your car and then leaves it alone?
typeeg
Apr 9, 2012 03:30 PM
EFjoe91
Engine Management and Tuning
Jan 7, 2011 10:54 AM
navin
Feb 20, 2004 06:20 PM
blykins
Apr 16, 2003 12:22 PM
zojirushi
Aug 16, 2002 03:24 AM
