Accidental down shift =\
Old Oct 22, 2007 | 06:15 PM
Danielh22vtec's Avatar
Default Accidental down shift =\
I was being a retard in my prelude the other night flyin up the road and when i went to shift from 3rd to 4th i went to 2nd , at 90mph......it shreded the power steering belt, and my clutch petal was stuck to the floor, i reached down and tugged on it and it poped right up, the clutch still works fine and there seems to be no prob in the trans or motor, im so glad i didnt send anything through the block , anyway, i was wondering if anyone knows why my pedal stuck to the floor....i scared me so bad.
thx
Old Oct 22, 2007 | 06:20 PM
dagle's Avatar
Default Re: Accidental down shift =\ (Danielh22vtec)
that would be your master cylinder... check for leaks and stuff...
oh and did you go completely into gear? or was it that you popped it half way in and it made a high pitched grind noise? in either case, get a compression test done...
Old Oct 22, 2007 | 06:25 PM
russlan44's Avatar
u could of bend ur valves, thats what happened to me, if u putted in gear.
Old Oct 22, 2007 | 06:31 PM
It went all the way into gear, but ive warped valves in other cars b4 and it didnt fill like i warped any, It still runs fine if not better b/c i have no power steering, but i put a big white sheet under tonite when i parked it so i will know for sure if it is leaking in the morning.
Old Oct 22, 2007 | 06:34 PM
russlan44's Avatar
oh, hope everything is ok, cuz when i missed shifted my timing belt over lapped and my valves were bend, car died but then i started and went home on it, it was working so crapy and kept on dieing if the RPM's were lower then 2k, this was at 2am in morining. i was young and stupid
Old Oct 22, 2007 | 06:44 PM
Oh, it scared me sooooo bad, i only bought the car like 5 days ago, the belt didnt bother me so bad, i could imagine it would jump off when the rpms jumped from like 4 to 9k in a split second, but when i went to put the car back into 5th, and i put my foot on the clutch pedal and it was just sittin on the floor, i about pissed in my pants, but it does seem to be running ok, i just really hope nothing is on that sheet in the morning.....it makes me fill sick
thanks for the info tho
Old Oct 22, 2007 | 07:42 PM
russlan44's Avatar
oh, nevermind, i miss shifted going all in 3rd around 90mph and putted into second which caused the belt to over lap and bend valves
Old Oct 22, 2007 | 08:27 PM
Sam_J's Avatar
did the same thing, slightly bent all my exhaust valves and a few intake valves, and blew out all my lma's.. and i also nuked my clutch.
As long as you dont have trouble starting it or getting in gear, your fine..
Old Oct 22, 2007 | 08:52 PM
DfwBB6's Avatar
Default Re: (Sam_J)
sup with 5th gen gens and downshifting? i know of too many pple who have been thru this mess
Old Oct 22, 2007 | 09:24 PM
AJ06's Avatar
Default Re: (DfwBB6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DfwBB6 &raquo;</TD></TR><TR><TD CLASS="quote">sup with 5th gen gens and downshifting? i know of too many pple who have been thru this mess </TD></TR></TABLE>
Im guilty too
Old Oct 22, 2007 | 11:46 PM
95greenlude's Avatar
its because they dont know how to "properly" shift a car.....
Old Oct 23, 2007 | 02:14 AM
ethereal2pt2's Avatar
Default Re: (95greenlude)
i managed to bend a few of my valves w/o misshifting.. does that make me a failure? probably wasn't too wise to hit 135 w/ a 172k motor eh?
Old Oct 23, 2007 | 06:33 AM
mattsnooz's Avatar
HAHAAHHAHA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">
its because they dont know how to "properly" shift a car.....</TD></TR></TABLE>
or downshift. You only down shift from third to second if your under 40 mph, not 90mph lol JK
I'd still get a compression test done. Than atleast if you find a bent valve, you can fix it b4 you over rev again.
Old Oct 23, 2007 | 06:45 AM
no1knows908's Avatar
Default Re: (ethereal2pt2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ethereal2pt2 &raquo;</TD></TR><TR><TD CLASS="quote">i managed to bend a few of my valves w/o misshifting.. does that make me a failure? probably wasn't too wise to hit 135 w/ a 172k motor eh?</TD></TR></TABLE>
My 92 H23 handles 140 just fine
Old Oct 23, 2007 | 06:03 PM
Default Re: (no1knows908)
Its not that i dont know how to shift, its that i havnt been drivin this car but maybe a week..... and i had a bottle in the cup holder which manged to make me angle my elbow upward while i was shifting back in to 2nd and 4th, and its hard to make a straight back line from 3rd to 4th with your arm above your head
Old Oct 23, 2007 | 06:21 PM
speedracer9k's Avatar
i would do a leak down test first, no point in waisting time on a compression test because if you find something with the leak down test you can pin point the problem right away.
Old Oct 23, 2007 | 07:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no1knows908 &raquo;</TD></TR><TR><TD CLASS="quote">
My 92 H23 handles 140 just fine </TD></TR></TABLE>
i'm not plannin' to do that again w/ my swapped h22a anytime soon until i get some better valvetrain components. not to mention a manual tensioner conversion. auto tensioner ftl.. that was one pita ordeal i am not willing to repeat..
Modified by ethereal2pt2 at 9:20 PM 10/23/2007
99hondadx
Feb 10, 2017 05:35 AM
F20B_accord
Sep 5, 2010 07:49 AM
scrap1ngsr
Apr 5, 2006 10:41 AM
93dx
Feb 3, 2005 02:40 PM
91_2.0_Si
May 20, 2004 07:05 PM
