trans question
my trans was just freshly rebuilt. before i installed it, it went into all of the gears. and when i first put in on the car it went in all of the gears except 5th. now its hard to go into all of the gears. and the car acts like it wants to take off in neutral (well atleast it appears to be in neutral when i shift it). and this is the same problem i had on the previous trans before i took it out. do you think that it may be the shift linkage is bent?
by the way its a jdm b16 trans with a jdm type r lsd and final drive
are you sure you installed the clutch kit right? maybe it was over torque'd I had this problem with a car before a kid installed his own clutch and all the gears started to take alittle more push than usaual to engage. it ended up being that he used a air ratchet to install the pressure plate and over torque'd.
yeah this kid his car ran fine than 3hrs later he said he started to act up. he brought it to me come to find out the clutch was over tighten. i'm not saying this is your problrm im just giving you possible reasons.
its a new clutch (ACT 6 puck and pressure plate), new flywheel(fidanza), new throwout bearing and new pilot bearing, i replaced all of these when i replaced the trans
ohsnapzafingcu
Transmission & Drivetrain
10
Dec 13, 2010 06:44 AM
