Operating Oil temp ITR JDM
Old Oct 22, 2007 | 04:51 PM
Rishiras's Avatar
Default Operating Oil temp ITR JDM
Guys,
I installed a DEFI oil temp guage, which measures in degrees C.
Anyone can tell me normal driving conditions oil temp reading? and when racing a bit on the road?
I am measuring 80-90 normal driving, and when hard driving (not racing yet) 100-105 Deg C, is this normal?
R
Old Oct 22, 2007 | 07:08 PM
EF9Fanatic's Avatar
Default Re: Operating Oil temp ITR JDM (Rishiras)
I am getting about the same temperatures as you. Although under harsh track conditions the temp rises to a little over 110C. Where is your temp sensor located?
Old Oct 23, 2007 | 06:23 AM
citrus3000psi's Avatar
Simple search return many results.
https://honda-tech.com/zerothread?id=816234
Old Oct 23, 2007 | 07:16 AM
an2ny888's Avatar
normal driving 100-105 c, at the track, it goes over 120 c
Old Oct 23, 2007 | 05:56 PM
ITR_cam's Avatar
Default Re: Operating Oil temp ITR JDM (an2ny888)
whats the safe limit for oil temp when racing? using 10w30
Old Oct 24, 2007 | 06:44 AM
Pompiuses's Avatar
Default Re: Operating Oil temp ITR JDM (ITR_cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR_cam &raquo;</TD></TR><TR><TD CLASS="quote">whats the safe limit for oil temp when racing? using 10w30 </TD></TR></TABLE>
That depends if your running quality oil or not. But a good rule is to keep it below 120-125*C. I usually slow down if my oil temp goes over 125*C when racing.
I know people are running 140-150*C oil temp, but that's just insain IMO.
Old Oct 24, 2007 | 08:05 AM
TPB's Avatar
TPB
Default Re: Operating Oil temp ITR JDM (Pompiuses)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">
If you're slowing down while racing to keep the oil cool, you should be running an oil cooler, otherwise what's the point racing?
I run between 100-110C while racing but I have an oil cooler to maintain that temp.
Old Oct 24, 2007 | 08:14 AM
Pompiuses's Avatar
Default Re: Operating Oil temp ITR JDM (TPB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TPB &raquo;</TD></TR><TR><TD CLASS="quote">If you're slowing down while racing to keep the oil cool, you should be running an oil cooler, otherwise what's the point racing?
I run between 100-110C while racing but I have an oil cooler to maintain that temp.</TD></TR></TABLE>
I'm only a hobby weekend racer. I can't afford to rebuild my motor after every track event I attend.
Yeah, an oil cooler is definately a must.
Old Oct 24, 2007 | 12:58 PM
ITR_cam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">keep it below 120-125*C </TD></TR></TABLE>
yea thats what i pretty much thought.. is it safe to use a thermostat with the oil cooler so the oil can warm up when just starting the car etc? or would this not be a good idea because once the thermostat opens your getting cold oil in the mix thats sat in the cooler/lines..
Old Oct 24, 2007 | 01:07 PM
donz's Avatar
i thought a stat is a must on most non track cars. I thought that this is because during normal street driving an oil cooler may not allow your car to get to operating temps, f course it depends on where you live too, the southern states is going to be different than up here in the great white north.
I heard a thermostat is not really necessary on a race car because the car is basically always going to have the thermostat open.
Old Oct 24, 2007 | 01:12 PM
ITR_cam's Avatar
Default Re: Operating Oil temp ITR JDM (donz)
sorry yes mine is street driven with occasionally track.. what you said is what i thought also.. i think the thermo would do less harm than good in this situation however..but yea i was told by someone who works at honda an has a 10,000rpm b18cr that thermo wont be a good idea due to the mix of oil temps?
Old Oct 25, 2007 | 02:43 PM
Rishiras's Avatar
Thanks guys,
Its just to know if all is measuring ok.
I thought so, over 120 is peak, and just to be on safe side.
My oil temp sensor is at oil filter , where i have a oil adapter.
R
realis9
May 23, 2006 08:55 PM
street dreams
Apr 2, 2005 12:17 PM
AllMotorHB
11
Jun 22, 2003 04:46 PM
577HondaPrelude
Apr 6, 2003 11:56 AM
