crx fuel pump not turning on
ok after i removed my hatch from the body i cut the wires that go to the wiper motor because i will be using an CF hatch. I also unbolted the 2 grounds i believe that are on the hatch itself. Now my fuel pumo isnt turning on for some reason. Would removing the hatch affect the fuel pump in any way??. Its a brand new walbro that ive had for 2 months never gave me a problem whatsoever. Usually i can hear it come on when i turn the key but now its not.
try hooking those grounds back up. also check at the plug, see if the harness is grounded. if so then hook up 12v directly to the wire and see if it turns on.
cleo7
Jan 23, 2013 08:53 AM
Xplicitz
Feb 6, 2010 03:13 PM
92redhatch
12
Aug 9, 2006 08:23 PM
DsMWookie
Oct 21, 2003 10:19 AM
