Electrical problem - No Dash lights, power windows, etc
Old Oct 22, 2007 | 11:23 AM
snowblind7x's Avatar
Default Electrical problem - No Dash lights, power windows, etc
So after taking my tranny off and putting it back on now none of my dash works along with my sunroof, turn signals and power windows. The only thing that happened that probly caused this was my friend touching one of the battery terminals to the wrong side. Fuse 13, the "meter" fuse blew and i replaced it but my problem still exists. All my fuses and relays appear to be good. Any idea whats wrong?
Old Oct 22, 2007 | 01:09 PM
mgags7's Avatar
I can almost bet you popped more fuses than just that one.
The car still runs? Just no electronics?
I'd check the big amperage fuses under the hood again.
Old Oct 22, 2007 | 01:13 PM
prelude-all-the-way's Avatar
Default Re: (mgags7)
dash and corner lights = small light fuse 20 amp
windows own fuse = 15 amp
sunroof probly a fuse
double check each fuse if not check for shorts
Old Oct 22, 2007 | 01:14 PM
JasonST's Avatar
Yeah check all ur fuses again, u might have even blown the same fuse (13) again, could be a loose wire grounding out.
Old Oct 22, 2007 | 01:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">I can almost bet you popped more fuses than just that one.
I'd check the big amperage fuses under the hood again.</TD></TR></TABLE>
Yeah car runs good. Oh, and remember my problem before that you were helpin me with? The hard shifting in and out of gears? Turned out to be a faulty pressure plate from exedy. I put my stock pressure plate back on and everything works great now. But anyway back to this. Not all my electronics are out, just the ones i named. My locks and climate control work still and all exterior lights work as well. Dunno if my radio would work cause its not hooked up. I've checked ALL my fuses many times. A friend was tellin me a fuse could be bad even if it looks good still. Sounds crazy to me but is that possible?
Old Oct 23, 2007 | 02:06 PM
Default Re: (snowblind7x)
alright so i just QUADRUPLE checked all my fuses under the hood and dash. They are all good. I even replaced all the under hood relays with known working ones. Still no luck. Could it possibly be one of the relays under the dash?
Old Oct 23, 2007 | 05:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowblind7x &raquo;</TD></TR><TR><TD CLASS="quote">alright so i just QUADRUPLE checked all my fuses under the hood and dash. They are all good. I even replaced all the under hood relays with known working ones. Still no luck. Could it possibly be one of the relays under the dash?</TD></TR></TABLE>
i just checked all the relays under the dash as well except that one big one cause i couldn't get it out. What the hell is my problem?!?!?
Old Oct 23, 2007 | 06:09 PM
speedracer9k's Avatar
did you check your fuses just by looking at them with your eye? sometimes just by looking you can never tell. the best way is to check continuity with a DMM or use a test light.
Old Oct 24, 2007 | 12:25 PM
Default Re: (speedracer9k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedracer9k &raquo;</TD></TR><TR><TD CLASS="quote">did you check your fuses just by looking at them with your eye? sometimes just by looking you can never tell. the best way is to check continuity with a DMM or use a test light.</TD></TR></TABLE>
i replaced all the possible fuses that my problems could relate to with brand new ones.
Old Feb 11, 2008 | 04:39 PM
inv4SIAN's Avatar
dude. I am having exactly the same problem. my radio and power locks still work, but not dash, windows and sunroof! I'm about to ohm everything out and double check everything. I'll let you know.
Old Feb 13, 2008 | 02:35 PM
Default Re: (inv4SIAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inv4SIAN &raquo;</TD></TR><TR><TD CLASS="quote">dude. I am having exactly the same problem. my radio and power locks still work, but not dash, windows and sunroof! I'm about to ohm everything out and double check everything. I'll let you know.</TD></TR></TABLE>
it ended up just being a loose wire on one of the plugs under the dash on the driver side.
Old Mar 2, 2019 | 12:12 PM
Bryan Krantz's Avatar
I am have the exact same problem as you. I have a 1996 Honda Accord. None of my windows, blinkers, dash lights works but my locks work. Very confused. I have check and replaced all blown fuses. Still nothing. Please help
Heart4Tuners
Jul 24, 2011 11:33 AM
IP RACING
11
May 6, 2008 08:31 PM
IMPACT
Feb 12, 2006 12:53 PM
ScottieA
Audio / Security / Video
Jan 23, 2006 12:01 PM
Si_Power
Jun 23, 2003 08:12 AM
