FNALLY! - Time for boost. Hondata on p74?
Can I run hondata s200/s300 on my stock p74 ecu on my '94 integra? I see alot of them sold with p28's...can i use p28 and p72 vtec ecu's eventhough i dont have vtec???
What all do i need when buying s300, data and interface cables, software, button, and ecu hardware. I dont need to "rom-programmer" if i plan to get it tuned by a shop rite?
also do i need a gm 3-bar map sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb18kid »</TD></TR><TR><TD CLASS="quote">
also do i need a gm 3-bar map sensor?</TD></TR></TABLE>
only if you plan on boosting over 11psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91redteg »</TD></TR><TR><TD CLASS="quote">itd be easier to tune a p28 unless its getting street tuned. </TD></TR></TABLE>
what does the ecu have to do with how it gets tuned? why would u recommend a p28 to an ls?
get it socketed and pin for hondata. if u plan to get it tuned by a hondata tuner than they should have the cables to communicate with the unit to tune. u only need to upgrade your map sensor when u want to run over 11.2psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb18kid »</TD></TR><TR><TD CLASS="quote">Can I run hondata s200/s300 on my stock p74 ecu on my '94 integra? I see alot of them sold with p28's...can i use p28 and p72 vtec ecu's eventhough i dont have vtec???</TD></TR></TABLE>
Yes to all of the questions. To use the P74, just send it in to Hondata or someone and get outfitted for S200 or S300. You can use the other ECU's if want to, it makes no difference. Just turn off VTEC in the program.
What all do i need when buying s300, data and interface cables, software, button, and ecu hardware. I dont need to "rom-programmer" if i plan to get it tuned by a shop rite?</TD></TR></TABLE>
Just buy the S300 from the Hondata dealer and the box comes with everything you'll need. You don't need the romulator at all if you use the S300. If you have the S200 then you only need it if you plan to tune yourself....which you aren't
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb18kid »</TD></TR><TR><TD CLASS="quote">also do i need a gm 3-bar map sensor?</TD></TR></TABLE>
As stated above, only if you plan to run more than 11psi. If you want more than 29psi, then you need a 5bar.
OP: Don't listen to this, it's completely wrong and just doesn't make any sense. The type of ECU plays no part in difficulty of tuning. All ECU's are equal since you are using the software to tune.
ok... thank you!! for me, a person who does not know that much about tuning, is hondata the easest way to go...keeping finance involved in the decision too?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb18kid »</TD></TR><TR><TD CLASS="quote">ok... thank you!! for me, a person who does not know that much about tuning, is hondata the easest way to go...keeping finance involved in the decision too?
Hondata is easy yes, but there are cheaper ways if you are worried about the money.
i suggest that u pick what tuner u are gonna use in your area, and then go with whatever they prefer, some shops wont tune crome and only want to tune hondata
Might I ask quickly what other alternatives there may be to hondata or crome? These are the only 2 I have heard of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustG »</TD></TR><TR><TD CLASS="quote">Might I ask quickly what other alternatives there may be to hondata or crome? These are the only 2 I have heard of.
- Autronic
- Motec
- AEM
- Hondata
- Neptune
- Crome
- Uberdata
Those are the only ones I can think of off the top of my head, but there are others out there too.
</TD></TR></TABLE>- Autronic
- Motec
- AEM
- Hondata
- Neptune
- Crome
- Uberdata
i hear good things about megasquirt too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC01GS-R »</TD></TR><TR><TD CLASS="quote">i suggest that u pick what tuner u are gonna use in your area, and then go with whatever they prefer, some shops wont tune crome and only want to tune hondata</TD></TR></TABLE>
best advice
best advice
[ <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSC01GS-R »</TD></TR><TR><TD CLASS="quote">i suggest that u pick what tuner u are gonna use in your area, and then go with whatever they prefer, some shops wont tune crome and only want to tune hondata</TD></TR></TABLE>
Thanks, I like that advice too!! Good heads up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoseRPunKx182 »</TD></TR><TR><TD CLASS="quote">i hear good things about megasquirt too
best advice </TD></TR></TABLE>
+3
My top choices: eCtune, Hondata, Neptune
best advice </TD></TR></TABLE>+3
