DC5 steering wheel in DC2 chassis
Old Oct 22, 2007 | 10:31 AM
SloazzEKhatch's Avatar
Default DC5 steering wheel in DC2 chassis
Has anyone ever tried this? I like the RSX steering wheels but i don't know if it is possible to put one in my integra. Anyone know?
Old Oct 22, 2007 | 05:30 PM
BlueIntegraBoy's Avatar
Default Re: DC5 steering wheel in DC2 chassis (SloazzEKhatch)
It is possible, but not worth it IMO, unless you have the tools or parts readily available. One way is the weld the Integra spline onto a DC5 hub. Another way is to bolt up a 96-00 Civic steering column into your Integra
Old Oct 23, 2007 | 07:13 AM
so the slpines are not the same? Why would the steering column work out of a civic and not the current one I have? I am just curious?
Old Oct 23, 2007 | 08:08 AM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
nope wont fit..put a ek column in there.
Old Oct 23, 2007 | 11:03 AM
I AM WEASEL's Avatar
Default Re: (SloazzEKhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloazzEKhatch &raquo;</TD></TR><TR><TD CLASS="quote">so the slpines are not the same? Why would the steering column work out of a civic and not the current one I have? I am just curious?</TD></TR></TABLE>
You answered your own question. The splines are different on a civic and integra column, therefore switching to a civic column you could run a dc5 steering wheel because they have the same spline as the civic
Old Dec 6, 2007 | 08:07 AM
br0nx finest's Avatar
Banned
Default Re: (-DC4-)
I'm curious as to this myself, because I've seen DC2's use the DC2R wheel as well as seen Civic's use the DC2R wheel. So if the DC5 wheel can be used on a Civic, why can't it be used on a DC5?
I know the wording sounds facking nuts, but I hope someone understands the question.
Old Dec 6, 2007 | 11:44 AM
[ iLL ] iNt3GrA's Avatar
Default Re: (br0nx finest)
dont the itr and ctr wheels almost look the same?
Old Dec 6, 2007 | 01:14 PM
onemore's Avatar
is the civic column a direct fit ?
Old Dec 6, 2007 | 01:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by br0nx finest &raquo;</TD></TR><TR><TD CLASS="quote">I'm curious as to this myself, because I've seen DC2's use the DC2R wheel as well as seen Civic's use the DC2R wheel. So if the DC5 wheel can be used on a Civic, why can't it be used on a DC5?
I know the wording sounds facking nuts, but I hope someone understands the question.</TD></TR></TABLE>
Odds are the civics that you saw had the ctr steering wheel whick looks prety much ientical to the itr one but they have a different spline. eg/dc have the same spline ek/dc5 also have the same spline dc2/eg spline ≠ek/dc5 spline
Old Dec 6, 2007 | 02:07 PM
imsickofrice's Avatar
Default Re: (-DC4-)
so how much would this cost?
i have a friend that has a S2K that took his steering wheel off for an aftermarket one.
Old Jan 4, 2008 | 06:46 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: (imsickofrice)
If you look at the back of the hub, the DC2 (and the 92-95, 88-91 Civic's too) there is a notch that runs vertical. The 96-00 Civics and AP1 and Ap2 steering wheel's notches run horitonzal. Hopes that helps!!
Old Mar 5, 2008 | 09:30 AM
jbecke2's Avatar
Default Re: (-DC4-)
does anyone know what parts you need to swap over the column from a EK to a DC2?
Old Mar 5, 2008 | 11:38 AM
StReCh4130's Avatar
Default Re: (jbecke2)
The DC5 steering wheel does not fit the EG/ DC2's dont make the same mistake my friend made. He bought the DC5 steering wheel b4 doing his research . lol.
Old Mar 5, 2008 | 01:37 PM
A08's Avatar
A08
Default Re: (emotionisdead)
bump for using a not equal to symbol.. in my years of reading and reading through honda forum after honda forum.. that is a first and well worth my 84th post in three years
Old Mar 7, 2008 | 12:14 PM
95blackegcoupe's Avatar
Default Re: (A08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A08 &raquo;</TD></TR><TR><TD CLASS="quote">bump for using a not equal to symbol.. in my years of reading and reading through honda forum after honda forum.. that is a first and well worth my 84th post in three years </TD></TR></TABLE>
x2,
xcept mine is the 76th post in 3 years... lol
ricb20vtec22
22
Jul 22, 2013 11:31 AM
twitch-572
Apr 12, 2013 09:19 AM
ITR 05082
Dec 11, 2010 08:29 AM
Eran
10
Dec 5, 2006 12:48 PM
Halo
Oct 23, 2001 12:16 PM
